Set up
  • Pau7060
    • Nov 2014
    • 67
    Set up
    Hi I am putting together a 27" hydro . Power is a Leopard 3674 - and Seaking 180 ESC . Space is limited for batteries. is is sportboat . But still want to get the right combo of pieces . What Batteries would I be looking for. Thanks . After 19 viewsI am still hoping for a little direction/help with battery issue. I am a new guy with only 26 post under my belt . Paul
  • wuzofoz
    • Jan 2015
    • 56
    not sure how help full i can be. i have only recently got back into boats.
    best i can suggest is work out you CG to see how much weight you need and measure what size (lxwxh) will fit in the boat then find a battery that fits both criteria.
    i have just finished building a 24.5'' hydro with very limited room and had to settle for a battery lighter then i wanted but is the biggest that physically fits in.
    hope this helps you
    • kevinpratt823
      • Aug 2012
      • 1360
      What is the kv of the motor?
      Which hull is it?
      Sent from my SCH-I535 using Tapatalk 2
      My private off road rc track
      • Pau7060
        • Nov 2014
        • 67
        Originally posted by kevinpratt823
        what is the kv of the motor?
        Which hull is it?
        Sent from my sch-i535 using tapatalk 2
        2650kv
        • JimClark
          • 5902
          sounds like a lot of power for not a very big of a boat
          Billy Graham
          • Pau7060
            • Nov 2014
            • 67
            BBY 27” Zephyr I found a simlar boat on line . Whiplash 21 built by Dr. Phil. Running gear is as follows. Leopard 3674 2650kv motor with Seaking 180 esc. (2) 4s Hyperion 45c 5000mah lipo packs connected in parallel for 4s 10000mah. Turning an Octura x440/3 blade prop. All purchased from OffshoreElectrics (OSE)
              • 8749
              Pic of the inside?
              • JimClark
                • 5902
                A plastic one?
                Sent from my KFTT using Tapatalk
                Billy Graham
                • Pau7060
                  • Nov 2014
                  • 67
                  Fiberglass/carbon reinforced.
                  • Pau7060
                    • Nov 2014
                    • 67
                    Well I will just going too learn the hard way, spend the money and off I go . Didn't much about Dirt Gokart Racing, but was winner with stuff I was told would never work.
                    • Heath M
                      • Mar 2008
                      • 806
                      with that KV motor and size boat id go 3s lipo. that will give you an unloaded total kv of 33390. start with a 640 prop and go from there.
                      Brisbane,QLD, Aussie
                      • Heath M
                        • Mar 2008
                        • 806
                        COG (center of gravity/balance point) between 1.5 - 2 inches from the back of the sponson. Strut depth start with the same depth as the sponson with the prop angled down slightly.(positive angle)
