h&m fast cat
  • Ub Hauled
    • Aug 2007
    • 3031
    #31
    Originally posted by roussos.p.antonios
    I will try the v937/3.I want to go 77mph.Please tell me do I have to careful samething special when i try?
    thank you.
    When you try it, go out for one pass and see if the temps are ok... let things cool down and try 2 passes and then check temps again. Don't run half throttle too much because it
    gets things hotter then they need to be.
    • ferfelu
      • Aug 2008
      • 6
      #32
      Hi roussos.p.antonio,
      I would like to know, what brand of ESC you are using..???
      Regards,
      Ray
      • roussos.p.antonios
        • Jan 2008
        • 37
        #33
        Regards,
        Ray
        Hi Ray
        the esc that i use is hi model 200amp. I have try also and HYDRA 240
        Regards
        Antonis
        • ferfelu
          • Aug 2008
          • 6
          #34
          Okey Antonis,
          But where can I find that Hi-Model 200A??
          Regards,
          Ray
          • Ub Hauled
            • Aug 2007
            • 3031
            #35
            You can find it
            HERE
            • ferfelu
              • Aug 2008
              • 6
              #36
              Thanks Ub,
              Is this Hi-Model the same as http://cgi.ebay.com/ws/eBayISAPI.dll...m=250292845889
              Regards,
              Ray
                • Jan 2008
                • 37
                #37
                Thanks Ub,
                Regards,
                Ray
                Hi Ray
                No they are not the same:
                hi model esc:Type: GX-200A-OPTO
                ● Weight: 124g / 4.37 oz
                ● Size: 65 x 40 x 16 mm
                ● Constant Current:200A (under good cooling condition)
                ● Max Current: 230A (for ten seconds)
                ● BEC: No
                ● Cut-off: 3.0V per cell for Lipo
                ● PWM: 8 Khz, 16Khz
                ● Input: 5 - 20 Ni-Mh/Ni-Cd or 3 - 7 Lipo (6-30V)
                and the mystery esc:
                Constant Current: 200A
                Input Volt: 5.6- 16.8V
                Max Current: 210A
                Low-Voltage Cutoff: Auto detect and set
                Size: 66mm x 38mm x 20mm
                Weight:115g
                regards
                Antonis
                • ferfelu
                  • Aug 2008
                  • 6
                  #38
                  Hi Antonios,
                  I just bought the Hi-Model 200A ESC and I would like to know how did you watercooled yours esc???
                  regards,
                  Ray
                    • Jan 2008
                    • 37
                    #39
                    Hi Antonios,
                    regards,
                    Ray
                    Hi Ray
                    i will post same pic. as soons as i can
                    regards
                    Antonis
                    • thrashmetal
                      • Aug 2008
                      • 82
                      #40
                      re cat
                      thats a great performing cat you have there.
                      very stable at high speed . im hoping my cat will get close to the speeds your getting with yours.
                      hydro & marine step 4 mono neu 1527 1y 6s
                      blackjack brushless 26 bone stock 6s 55.4 mph
                      ballistic racing team
                      • focused
                        Dutch Electric Powerboats
                        • Jul 2008
                        • 237
                        #41
                        Mmmm, 125kph not possible ? i dont think so , they have reached the 150kph already whith this hull .
                        H&M Agitator 150kph
                        Got my Agitator in de 90`s kph with a feigao 54xl9 and 6s lipo and 42K prop.
                        cheers
                        Michiel.
                        • Eyekandyboats
                          • 1921
                          #42
                          money makes a boat go fast
                          skill will make it handle and take a turn for a oval course.
                          i'd like to see a 125Km/H heat racing boats using this hull.
                          EYEKANDYGRAPHICS
                          www.rclipos.com
                            • Jan 2008
                            • 37
                            #43
                            last Sanday i try 6s lipo with x440/3 ....110km on gps and with x442.....108km on gps
                            i hope next week i will try to hit 125km
                            Antonis
                            • ferfelu
                              • Aug 2008
                              • 6
                              #44
                              Hi Antonis,
                              I'm still waiting for some pics..
                              Regards,
                              Ray
                                • Jan 2008
                                • 37
                                #45
                                Hi Ray
                                I'm Sorry you will have the pics. till Sanday
                                Regards
                                Antonis
