To Skeg or not to Skeg,that is the question
  • Heath M
    • Mar 2008
    • 806
    Hi All,
    What's the consensus on using a strut with skeg or a strut without skeg on a catamaran? 4s1p, offset rudder, for racing.
    Brisbane,QLD, Aussie
  • RaceMechaniX
    • Sep 2007
    • 2827
    Depends on the hull. I have run an AM Mean machine with no skeg for heat racing, but on an AM Conquest it definitely needs the skeg. With a smaller P size hull you can probably skip the skeg strut unless you notice the bad sliding badly.
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Heath M
      • Mar 2008
      • 806
      Hey Tyler,
      Hull is a H+M Intruder S, I've decided to go skegless as i ran a skunkworks gen 1 cat which is similar size, without a skeg and had no troubles in the corners. Just thought I'd ask the question to see what others thought.
      • dasboata
        • Dec 2010
        • 3152
        The only reason to use a skeeged sturt on a cat is if your cat is hooking or sping out in a sharp turn other then that it only creates more drag !
          • 8011
          The typical strut skeg is so small - and is often partly out of the water - that its overall contribution to cornering is relatively minor. Many times a skeg is needed because the builder used a small rudder, or cut a larger one down too far. .
          • Heath M
            • Mar 2008
            • 806
            Thanks guys, that makes sense.
