I have question on what to expect for top speed from the veterans here. I have a Genesis with a Leopard 3674/1900kv and a Seaking 180a esc. On 6S, my gps is registering 44 mph and on 4S, I am getting 32 mph. The hardware is all stock with a copper 38mm 1.4 prop, same as the stock plastic prop. After a run, the motor and ESC is at 86F temp wise. Are the speeds I am getting inline with expectations or should I be running a bit faster?
Question on speed expectations.
Tags: None
The speeds are well below what I'd expect with that motor and prop on 6S. With the low temperatures I suspect poor prop efficiency, probably due to the small diameter. Try an x442 first, but check the temps after two minutes. An m445 would be the next step up. A 40mm motor would probably work better.....
I'm surprised it gets on plane with that prop. i tried one of those on a 26" cat i have and it was slow as could be. I'll agree 100% with fluid, he's right on the money.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
My Genesis Neu 1515 2200kv 6S very modded 642 prop ran in 70's...its a great hull, lots of potential.... DJ
Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
Thanks guys for the help. I tried to play around some with the prop angle and it has seemed to help. The prop was pointing upward too much. Now that I have lowered it down, I am getting runs in 45mph range with the 4S battery. I have not tried 6S yet. But I also agree that the prop I have is not the best prop. Will upgrade to a 440 or 442 and see what happens.Comment
