ok ill give it a shot today and see
heeelp
BEC
Disable BEC= take out the red wire Simple as that. IMO You shouldn't ever run a BEC, it's just asking for trouble at some point. I heard t people say that and disregarded it, but I have found this to be true.
Water.
Put a piece of heat shrink from the stuffing tube to the strut, a piece of silicone tubing over the stuffing tubing (inboard side there is a pic in one of these threads that Jay posted.) Then do a bath tub test with the flex shaft in the tubing just like you were about to run. If still getting in water, then use the same grease as you use on your flex cable. You can see the piece of tubing I am talking about here on the Titan better and the grease in the hydro better, it's the green stuff.Attached FilesComment
