Stinger Length
  • PowerDemon
    • 351
    Stinger Length
    I am going to be building a Mystic Study 7700. It is a 56” mono. How long do the stingers have to be for the best performance? Will the Speedmaster 85mm struts be suitable for this boat or should I go for a longer pair of stingers on this boat? Thanks!
  • Alfa Spirit
    • 2131
    85mm is short, 120mm is good
    • PowerDemon
      • 351
      Have you used 85mm ones before? Is there anything wrong with them?
        A lot depends on how low you mount the stinger on the transom. The lower you mount it the shorter the stinger usually needs to be; this is because the longer it is the deeper in the water the prop runs, lifting the boat.
        It is not uncommon to cut the stinger shorter after mounting it to tune how the boat runs. Start with the longer version, you can always shorten it.
        • PowerDemon
          • 351
          So I should get rid of the 85mms and get longer ones?
          • Fella1340
            • May 2013
            • 1035
            The stingers do seem a little short. The 48" mono I am doing (single) has a 125mm long stinger. The size was based on information gathered on this site from the experts like fluid and others that have been very successful. I would take the above advice and move onto a longer stinger, as mentioned you can cut it down. Had I gone ahead on my own the stinger length may have been ok but the height I would have drilled the stuffing tube at (as low as possible) likely would have caused me lots of grief. Follow the advice of those that know there stuff and you'll end up with a great boat. I spent countless hours reading through all the top guys builds and advice given and it was worth every minute of it. I look forward to following your build. You got one sexy boat on its way to you!
            • PowerDemon
              • 351
              Thanks! I just got it today.. It is amazing! My first Mystic. What kind of stinger did you use?
              • Alfa Spirit
                • 2131
                This stinger is very good, with 1/4" flex shaft stepped down 3/16" that' s perfect for the Study. What will be your setup?
                • Fella1340
                  • May 2013
                  • 1035
                  Hey Demon, the stinger I used is not something I would recommend. It's somewhat different in the way it adjusts and is something I just wanted to play with. It's servo adjustable and by no means considered practical. The water closest to home is lake Ontario and is never predictable so I thought I would try it out. It intrigued me because of my background in machine building as it's created it's own unique obstacles to overcome. Luckily it can be locked down manually and used as a normal stinger.
                  I don't have the experience with anything else to recommend but with the boat you've choosen I am sure the experts will be along to help out. I hope we get to see some pictures of your new baby!
                  • PowerDemon
                    • 351
                    Took some photos of her,
                    She is a beast. The photos don’t do it justice. Now that I can compare the stingers to the overhang of the transom I do think they are too short. Kintec sells a set that look right for this. Does anyone want a pair of Speedmaster 1/4 Gas stingers? Lol.
                    • Rocstar
                      Joel Mertz
                      • Jun 2012
                      • 1509
                      When you asked me before, I was still thinking of the DF Sniper you wanted to build. You'll want something longer for the MHZ Study. I ran a set of MTC 115mm stingers on my Outerlimits. Worked out well.
                      • PowerDemon
                        • 351
                        Oh ok. Yeah I am going to go longer on the stingers. I looked at the MTC ones but they are a bit out of my price range. Do you have any other suggestions?
                        • Rocstar
                          Joel Mertz
                          • Jun 2012
                          • 1509
                          Maybe these. Never used them myself though.
                          • PowerDemon
                            • 351
                            I was looking at them. They should do the job. I might also just go ahead and get the MTC stingers. They look like they are worth the money.
                            • Rocstar
                              Joel Mertz
                              • Jun 2012
                              • 1509
                              They are.
