Twin out runners have such a cool sound !
Formulating some ideas, need input
.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s -
No Tim, too late you done got all of us interested now...that does look tight in there, just a thought. Could you not mount 2 motors in the center and bend your stuffing tube around enough to match up ?...I was thinking about doing this with my twin fantasm build I got planned, so it would be easier to get motors out etc... I had been wondering if this could even be done or not... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
You should be able to convert the stingers to use a floating brass bushing. Use a piece of brass tubing to reduce the diameter of the stinger to fit the brass bushing and loctite it in place.Comment
You would be surprised what you can make nice with very basic tools and patience.
I used little ProBoat 1800kv motors in my Geico twin with short drives and .150 cables. It has been a real good runner and only needs SK 120's.
Shawn
PS: here is the build http://forums.offshoreelectrics.com/...n-G&highlight=Comment
Yeah, at the moment it only is reverberating in my empty skull.
( I can hear Doby snickering in the distance....)Too many boats, not enough time...Comment
A hack saw, then finish up with a bench top belt sander will work fine. If you don't have the sander, clean up the cut with a file then 200, 400, 600 wet/dry sandpaper.
You should be able to convert the stingers to use a floating brass bushing. Use a piece of brass tubing to reduce the diameter of the stinger to fit the brass bushing and loctite it in place.Too many boats, not enough time...Comment
Shawn
PS: here is the build http://forums.offshoreelectrics.com/...n-G&highlight=Too many boats, not enough time...Comment
Mount the motors in the center on the tunnel floor, no room in the sponsons...I've never tried bending a stuffing tube into what would be a long S, but I do know that some do S bends in all their hulls....sure would open up the motor options.... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
