Scotch Weld Black for Carbon?
  • HyProBuildV1
    PropzBro
    • Nov 2014
    • 10
    Anyone using this to mount carbon fiber motor mounts? What is everyone using for the twin cf mounts in these cats?
    YOUTUBE-HyProBuildv1
    HyProBuildV1/Facebook
    • 7673
    That is interesting. I have been just using a good 24hr epoxy by System Three. On the current build I added cloth support on the corners of mounts but this is the first I have done this on. The others have held up fine with no broken mounts even after the flips at 70 or so MPH
    This stuff should work fine. Except for the 20 minute work time.
    • HyProBuildV1
      PropzBro
      • Nov 2014
      • 10
      I have used JB on a few mounts on hydro's, an never had an issue...But It can be difficult to use sometimes...in the "Neat" department.
      • Chilli
        • Jan 2008
        • 3070
        JB weld has worked very well for me in my CF mounts. Even on my SAW boats that have had numerous blow overs at 90. Scuff the CG good with some 120 grit and wipe clean with alcohol. For clean lines, throw down some masking tape before applying. Apply the JB and your mount, run your finger down the bead if necessary to make a nice fillet and then remove the masking tape. The JB will sag a bit but you will have a nice clean install.
        But to tell you the truth, I've never seen any epoxy fail that wasn't attributed to lousey surface prep.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • HyProBuildV1
          PropzBro
          • Nov 2014
          • 10
          I'll agree with that. I have used JB weld on every boat I have had, but I was just curious as to what others are using, JB mixes well to a grey color, Most of the twin cats I have seen, after cure, its a nice gloss black..Just trying to figure out what they were using. No biggy Though.
          • kevinpratt823
            • Aug 2012
            • 1361
            I have been hearing of this "G/Flex" epoxy on a few build threads lately, it was on my list to research, not sure which version people are using but I'll take a look again.....http://www.westsystem.com/ss/g-flex-epoxy
            My private off road rc track
            https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
            • siberianhusky
              • Dec 2009
              • 2187
              I just mixed up some JB with a pinch of black mortar pigment, certainly made it black!
              The pigment is plain old carbon, anybody think it will effect the epoxy?
              I'll post back later to let you know if/ how it cured and if a can feel any difference in bond using the highly calibrated hand pull test!
              Bonding a couple pieces of fiberglass plate.
              • kevinpratt823
                • Aug 2012
                • 1361
                I have seen in one of Rocstar's builds he used graphite to blacken epoxy, it looked great.
                • Rocstar
                  Joel Mertz
                  • Jun 2012
                  • 1509
                  West System G/Flex works great. I use it when I only need a small about like a single motor or servo mount.....easy 50/50 mix.
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    Which blend of G/Flex are you using? And what do you use otherwise if not the G/Flex Joel?
                    • Rocstar
                      Joel Mertz
                      • Jun 2012
                      • 1509
                      G/Flex 650. I also use West System 105 with 207. I like to control the viscosity with 406 colloidal silica.
                      • flraptor07
                        • Aug 2013
                        • 2451
                        I use 30min. Zpoxy mixed with ground CF for strength and to make it black. Tape the edge and you get a nice finished line when set. Or if you're using with regular Epoxy fiberglass mix it with milled fiberglass to make it white. DSC02678.jpg
                        • HyProBuildV1
                          PropzBro
                          • Nov 2014
                          • 10
                          Lot's of info here, Thanks for the input Guys. Now to decide what to try first...Its not cheap!
                          • dasboata
                            • Dec 2010
                            • 3152
                            I use JB weld never had a problem and you can heat it to remove it. Mike no cooling can ?
                            • rickwess
                              • Apr 2013
                              • 777
                              Epoxy pigment works great with G/Flex. You substitute it by weight for the resin. For black I've found that just a VERY VERY small amount is all you need.
