Has anyone used this device?
  • Make-a-Wake
    FE Rules!
    • 5557
    Curious if anyone has tried this.............
    Sikowd memberikan layanan deposit terlengkap dari bank apa saja dan deposit via qris super cepat hanya 1 detik langsung masuk ke akun anda, Nikmati keseruan tanpa batas dengan deposit super cepat dan peluang menang super besar di setiap permainan.
  • bozo586
    • Aug 2009
    • 344
    they work great with my boats----i used them this year on every boat i ran! didn't have any signal problems all year.
    • tlandauer
      • 5666
      Yup.
      I had a Traxxas Stampede that I upgraded with Novak BL motors and the servo would always glitch no matter what i did, put one of these on the Rx and it was great!
        • 9488
        Sweet!
        I'm going to pick up about 6 of these
        • flraptor07
          • Aug 2013
          • 2451
          Yup, when ever I have a glitch problem I use one of them and 99.9% of the time it cures it! At one time NitroRC was giving them away with every servo they sold, that's how I found out about them.
          • 3-UP
            • Jul 2014
            • 97
            What if you don't have a extra spot on your receiver ?
            • rickwess
              • Apr 2013
              • 777
              It works in the bind location as well. I use in in all my RCs (cars and boats). It's cheap insurance against glitches.
              I wish Steve carried them. Kintec sells them (hard to find but it's right on the home page).
                You can make them soooo easily......
                Fyi, if you use a receiver pack or an external bec, you can put it on a "y". It works the same way a cap bank does with batteries.
                • littlepooper206
                  little member
                  • Jul 2014
                  • 159
                  Can you make one as well? So you have an extra capacitor and just slaughtered it onto the wires itself.
                  • littlepooper206
                    little member
                    • Jul 2014
                    • 159
                    Solder
                      Yes. When I get home I'll look at one and tell you what cap to use.
                      • rickwess
                        • Apr 2013
                        • 777
                        It's only $4 at Kintec.
                        The cap is in the 3000uf range and anything over 10V. Easy to make it you have the female pins and connectors..........or butcher an existing cable.
                        • kevinpratt823
                          • Aug 2012
                          • 1361
                          I have been using them for years in many of my cars. Savox servos draw a lot of current, and Spektrum rx's are sensetive to low voltage, together this combination has become notorious for "brown outs", enough that AMain hobbies actually puts in a footnote warning on the Savox servos that suggests capacitors with this combo. It basically backs up a weaker BEC from voltage drop browning out the receiver under servo load. On my track, with very high speed/high torque Savox servos, every time I hit an "S" turn, where the steering went full left-full right, I would get a brown out and the ESC would have to reboot. The glitch buster would fix it with most, but so would a good external BEC, which I ran for higher voltage servos. I also never had the issue with nitro cars that ran a rx pack, and those had 2 of the same high speed/ high torque servos operating at once. I personally haven't had this problem in any of my boats, even the 2 with savox servos, perhaps because the use an rx pack, perhaps because the servos are slower, or maybe just not as much load, but they certainly wouldn't hurt. I have tried them in all my boats when trying to resolve reception issues, but they didn't help my particular issue. A simple "Y" harnesshttp://www.offshoreelectrics.com/pro...?prod=dh-1614f does the trick if all your rx ports are taken, like with the MR200.
                          My private off road rc track
                          https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                          • NativePaul
                            Greased Weasel
                            • 2761
                            No, I use Futaba FASST and get no glitches to bust.
                            • Doby
                              KANADA RULES!
                              • 7280
                              Ditto with my Tactic systems..
                              Grand River Marine Modellers
