GPS Signal In Cabon Fiber Boats
Michigan Fast Electric SAW Club
Revolt - 76.9mph...Building a DF35- Project MonoComment
Kaotic,
Thanks soooo much for the offers on several aspects. really appreciated.
I did have a thought on cutting out the CF and gluing in a piece of plexy glass from the bottom side. Then I would mount a Quanum GPS right under it so it would get signal and I could read it without removing the hatch. The Quanum is about 1" x 3" in size. But after looking at my 3 boats... this would work on the fighter cat, but the pursuit and viper do not have significant flat areas on the hatch so I would have to cut into the hull itself to do this.
Not to sure I want to do that.
On the paint... My wife's uncle does custom paint on motor cycle tanks, fenders and helmets so I plan on approaching him to do all 3 of my boats up real nice.Have fun with that....Comment
Yeah, I've heard about the radio issue but wasn't worried since I plan on having an external antenna tube. But as I considered buying the Quanum GPS loggers I realized this could be an issue for GPS as well.Have fun with that....Comment
I have not done this yet...but my take on it.... I feel like in a hard crash that becomes a failure point. What happens if it detaches when you have a hard slap againt the water......... guess youll find out at that point a few things.... (if the glue used holds and if not, if you put enough floatation in the hull and if your electronics are truly waterproof)32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I like the idea, but I have so much to do already over this winter with 3 boats under construction.Have fun with that....Comment
Agreed... one thought I had was to use 4 to 6 small bolt/nuts to unsure the glue/epoxy does not give. The glue/epoxy basically become a water sealing agent at that point. Could have a nice finished look. I will continue to ponder and update if I decide to go down that road.
I like the idea, but I have so much to do already over this winter with 3 boats under construction."There's nothing else I really want to do other than get up and build boats." - Mike FioreComment
Could use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy.Have fun with that....Comment
Could use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy."There's nothing else I really want to do other than get up and build boats." - Mike FioreComment
Could use an alloy/aluminum support ribbon around the interior perimeter. This would allow for the pressure from the 6 bolts to apply equal force around the entire opening. And we're only talking about a 1" x 3" cutout that would be sealed with epoxy. I think there would be a much higher risk of the entire hatch coming off if the crash was that hard. After all, were comparing a single layer of tape holding down a large hatch verses 6 bolts and epoxy holding a small piece of plexy.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I also like Jeff's idea, but if I'm going to paint a cf piece to cover the body work I might as well just find that fg hatch somewhere.
I really can't believe these things are not more readily available. I have to believe a few have been lost during a hard crash to the bottom of the lake. And I've seen some body work completed on racer's hatches do to crashes with other boats.
Worst case for me is that I will purchase an entire fg hull, take the fg hatch, and then resell it with my cf hatch on the boat.
I'm just discussing the possibility of this plexy idea so I could save some money on 3 boat hatches, keep the cf look throughout, and generally think it may be cool looking.Have fun with that....Comment
