Next step for hornet.
  • Zen
    F1 junkie
    • 116
    Got a hornet hull to check out electric f1. I purchased a SK 120 pro esc
    And a leopard 3650. Added 3s 4500mah lipos all on a OS leg I had from nitro. tried various props with various results. Bottom line is the boat isn't fast enough for me. What would be the next step motor esc battery configuration. I run 1/4 gas F1 that's why I want to go faster.
    Doesn't matter, real or RC, boats are just a hole in the water where you throw your cash.
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    What KV was the 3650 motor?
    • Zen
      F1 junkie
      • 116
      2290kv
      • jim82
        • Jan 2013
        • 1358
        try a 4s if it will fit
        • Zen
          F1 junkie
          • 116
          I think I can do that. Ok to use 2 2s. In series. Correct? Just checking.
          • jim82
            • Jan 2013
            • 1358
            you can or just get a 4s lipo up to you
            • jim82
              • Jan 2013
              • 1358
              Always check your temps after a 45sec to 1 min...run
              • Zen
                F1 junkie
                • 116
                Yes. I'm a lil fanatical about the temps on my motors. Even my gas motor. Heat is bad. Thanks. I'm probobly just use 2 2s for now to see how it works. Thanks.
                • jim82
                  • Jan 2013
                  • 1358
                  Not a problem let me know how it turns out
