Weird flex cable
  • T.S.Davis
    • 6220
    Weird flex cable
    Anybody ever had a .187 cable measure out at .174"?
    Explains why I could never get a coupler to hold.
    Noisy person
  • Rocstar
    Joel Mertz
    • Jun 2012
    • 1509
    Nope. Usually around .185. I had one at .182, not sure where it came from.
    • revoltrunner
      • May 2014
      • 646
      sounds like a 4mm shaft to me.
      here's a variety of collets that will fit that flex.
      • T.S.Davis
        • 6220
        Another interesting thing about this one. It's not very flexible. Like half as flexible as another I had on the shelf. I don't know where this goofy one came from.
        Noisy person
          I just measured mine. It was at like ,
          .162 but.....I stripped it out Saturday. ..does that count? Lol
          On a serious note, I'll go measure a few I have real quick and see where they come in at.
          • revoltrunner
            • May 2014
            • 646
            did it come from your Libero.
            • T.S.Davis
              • 6220
              No. It's stole it out of my old Wildthing. I've had problems with it before. I thought it was because I didn't solder the end. So I did. Threw it in the whip after cutting about a 1/4" off. Spun in the coupler.
              Noisy person
                All the ones I measured were right. I've noticed some have small wire and some have big wire. Is it possible that the cable tightened up a little reducing it's diameter and making it stiffer.....as a result of not being wound correctly at the factory?
                • keithbradley
                  • 3663
                  Yes. TFL made a bunch like that. I think I still have one or two.
                  www.keithbradleyboats.com
                  • longballlumber
                    • 3132
                    So the plot thickens... Is this the same flex shaft that was being used at the same time you were swearing off Octura couplers?
                    Last edited by longballlumber; 10-02-2014, 08:52 AM. Reason: I should have put some smiley faces
                      Ugh o...lol
                      • T.S.Davis
                        • 6220
                        IDK Probably. Thinking back though....... The one that I was having problems with in the WT was pretty torn up. So Tom and I soldered up a fresh one with StayBright on the end. The new one was probably a TFL. Went to a TFL coupler too. Then the next day racing PAGS for P mono I stuffed and nearly lost the boat. Lost a battery pack and killed another in the wreck. Acckkkk! It may be that the new shaft wasn't going to hold up long either and I just didn't find out because the boat was a mess. So the original shaft could have been undersized too for all I know. I can't remember where the original shaft came from. I wasn't into TFL when I built it winter of 2010 so it was likely a Hughey. Without being able to measure the old shaft I can't say for sure if it was the coupler or the flex size.
                        Last night we had two 3/16 shafts sitting side by side. That's how we noticed it.
                        I did find a fresh Hughey shaft for the dinosaur Whip in my drawer of debris. That shaft measures .187 on the money. The actual wire in the cable is larger than the wire on the undersized cable. I'll test again on Saturday with various couplers and see how it goes. I did get one good run on it before the grip on the coupler gave out.
                        I'll be checking all shafts when I buy them from now on.
                        Noisy person
                        • ray schrauwen
                          • 9472
                          Maybe a Hydro Marine. Their cables are far more rigid for their diameter compared to Hughey or others...
                          I'll take it of you want to get rid of it... lol..
                          Nortavlag Bulc
                          • T.S.Davis
                            • 6220
                            Originally posted by revoltrunner
                            1.74" is 4.4196mm
                            IDK. Moving on.
                            Noisy person
                            • revoltrunner
                              • May 2014
                              • 646
                              1.74" is 4.4196mm
                              IDK. Moving on.
                              I think the 4mm collet would grip it fine though.
