Mounting holes out of spec, frustrated
  • tlandauer
    • 5666
    Like the title says, anybody here had experienced this? Got a new motor ( brand name withheld for the time being), the holes are just a hair too far apart, there is no way the screws will go in, I tries all three pairs ( 6 holes total) , and stripped one hole. I am not going to file the motor mount holes wider. E mailed to the maker and let's see what they say.
    Spent the entire afternoon trying to fit that motor....
  • gsbuickman
    • Jul 2011
    • 1292
    Dam Tim, that sucks.I've run into this issue a timer to in the past. my take on it is their factory seconds that somehow made it past QC.I just returned / exchanged them for new ones rather than file out the motor mounts and ruin them.
    • dasboata
      • Dec 2010
      • 3152
      Do you mean the mounting holes on the end bell , Just open up the motor mount holes with a drill, to get the clearence you need easy fix if you need use washers, Good luck
      • Rumdog
        • 6453
        Nah. I'd send it back
        • tlandauer
          • 5666
          Thanks guys.
          I would have enlarged the hole and looked the other way, but to me it's the principle of the thing. Also this boat has a Neu 1515 1y as a regular motor so I don't want to upset the motor mount.
          I was mainly pissed at myself for too trusting: the space was so narrow and I was cursing myself and never thought of anything could be wrong with the motor's endbell.
          Another lesson learned...
          I am sending it back regardless what they say, don't need a dead paper weight. lol....
          • revoltrunner
            • May 2014
            • 646
            Thanks guys.
            what motor is it , maybe I can use it.
            • dasboata
              • Dec 2010
              • 3152
              Thanks guys.
              Can you save the thread by running a tap threw it ? It's worth a try if it bothers you that much ?
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                That is bizarre, never seen that happen. I'm just gonna take a silly guess here. USA based motors could have a 1 inch distance in the mounting holes, while all others are 25mm. That could explain the hairline difference of about 0.4mm or so. Just guessing here as I have never seen an end bell out of alignment like that.
                Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
                "Follow someone's footsteps and you will always be a step behind"
                • tlandauer
                  • 5666
                  I am waiting for reply working now, will PM you.
                  Sent from my Droid using Tapatalk 2
                  • tlandauer
                    • 5666
                    Will see what they say, don't want to void the warranty, if there is such a thing.
                    • tlandauer
                      • 5666
                      Chinese made I have five 36xx of these motors. Hole pattern is 25mm.
                      Thanks!
                      • flraptor07
                        • Aug 2013
                        • 2451
                        How far off is it, some motors have two different bolt spacings. Did you try aligning it with another set of holes?
                        • tlandauer
                          • 5666
                          Yes. I did. All 3 sets of them.
                          • siberianhusky
                            • Dec 2009
                            • 2187
                            If this is the motor I'm thinking I had the same problem, I have a shorter can but same diameter from the same man. and it bolts in no problems in a standard mount, the longer one was a no go.
                            I opened the holes in the mount a hair on each side. Not implying that makes it right though, Interesting one of mine fits and the other doesn't, I figured they'd use the same ends for all the lengths of a given diameter.
                            • tlandauer
                              • 5666
                              I have five 36xx series with various can lengths with absolutely no problem. This was supposed to be a 4074 sized motor but the can is more than 80mm long. It is not 83mm as its "supposed" to be. It is more like 81mm. I am at a total lost. I am not sure when the spec was changed because their site still says that it is a 74mm can. I am sending pictures to the cust. support dept.
                              Very interesting experience to say the least.
                              I have found a Leopard motor to use for the time being.
