Total Melt Down! Why??
  • rickwess
    • Apr 2013
    • 777
    #46
    How hard would it be to put your SF ESC in you so you could check the logs for current, etc?
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1136
      #47
      Originally posted by MarkF
      I think that was a common problem with the fightercat esc and not your set up. Also the harder your going to push your equipment the more you need 0 deg timing.
      Mark
      Mark, tks I knew that I wasnt totally lost in my turn the timing down statement, that I had been told or read about running 0-5 on any Neu motor D or Y wind if you were running larger worked props on heat racing setups... I do see turning up the timing some for an attempt at a "SAW" record since those only involve short runs...
      Travis, dang brother, I thought It was me who is nicknamed the Magic Smoke Wizard .... DJ
        Mark
        Well mark. ..X646/3 prop...not detounged, 1515 castle, 2200kv on 6s.....I can't really say it WASN'T my setup either...lmao....boy have I learned alot in a short amount of time lol
          Fwiw...with my 1800kv 1518 y wind castle I saw about .2mph turning the timing from low to 15 in my setup. My timing is at 0 right now, but I am running a neu d wind motor.
          • Rumdog
            • 6453
            #50
            D wind- 0-5 degrees
            Y wind- 10-15 degrees
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 979
              #51
              Travis if you keep your runs to a couple of passes you can get away with quite a bit. I ran a 15271d on 6s and a 5018 prop for 2 passes 102 mph average using a SK 180. I don't think it would have made a third pass but goes to show how hard we can push things sometimes.
              Rumdog
              I wouldn't agree with those numbers but what do I know.
              Mark
                Rumdog
                Mark
                Was that the twin Shocker you had that I had talked you you about when I was building mine? Think it had cnc fightercat props on it or something?
                • Rumdog
                  • 6453
                  #53
                  You don't have to a agree, but they're pretty much spot on. It's been covered hundreds of times here on OSE. At least once a week motor timing comes up.
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 979
                    #54
                    Yes twin shocker and props are fightercat. Good props by the way.
                    Mark
