Total Melt Down! Why??
  • tlandauer
    • 5666
    I'm not sure how you're getting away with running a X447/3, I'm running a Y547/2 and mine gets just a little on the warm side (125-130) if I beat on it hard.
    I thought the Y547 is more aggressive albeit only a 2 blade. man,where have I been all this time!
      • 8011
      Too much prop for Summer running! We often have to run smaller props in Texas' Summer heat, larger props in Winter. A motor which starts out 30 degrees hotter in Summer will usually come in 30 degrees hotter. A Neu is not a Leopard and will often pull more amps in the same aggressive setup; different cell quality matters too. What timing was used?
      • tlandauer
        • 5666
        Originally posted by dasboata
        Let me see a few pics of that boat
        Here they are, Chris,
        I just used a non-locking nut to secure the prop for these pictures.
        • dasboata
          • Dec 2010
          • 3152
          the 547 has 2.849" of pitch and the 447 has 2.590 but it does have another blade which will add some load
          • tlandauer
            • 5666
            15*,
            I think I learned a valuable lesson today!
            Thanks for pointing out that a Neu will pull more amp in this set up than a Leopard, that is something I had neglected to consider!
            • tlandauer
              • 5666
              I see, I looked at the dia. and pitch as my guidelines. I honestly thought the addition of one blade would not have added that much load.
              Thx !
              • dasboata
                • Dec 2010
                • 3152
                The prop looks well done,, did you do it ? The only thing it, it's going to eventually blow a blade off,, with the heavy barr cuts , you also have some added tip cup in there,, I would concider putting a water pickup threw the hull in the bottom of the right sponson turnfin side,, pretty old school but reliable
                • tlandauer
                  • 5666
                  I bought the prop used here from someone. I see the tip cup.
                  Thanks for the suggestion on the location of the water pickup.
                  • dasboata
                    • Dec 2010
                    • 3152
                    Can you take a pic of the engraving on the hub please
                    • tlandauer
                      • 5666
                      Ok...[ATTACH=CONFIG]120558[/ATTACH] [ATTACH=CONFIG]120559[/ATTACH]
                      • dasboata
                        • Dec 2010
                        • 3152
                        OK I don't see any engraving on there ? looks like my finish,, but I don't barr cut like that, that prop also has added pitch on the trailing edge,, I would try a smaller prop as suggested by Jay thanks Chris
                        • olwarbirds
                          Magic Smoke Wizard
                          • Oct 2012
                          • 1136
                          #27
                          Tim 15* is too high for a Neu brother, try 5* that will help alot.... DJ
                          • Luck as a Constant
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #28
                            • ron1950
                              • 3024
                              #29
                              will the motor run cooler if timing is set back to 7.5?
                              • Rumdog
                                • 6453
                                #30
                                15 degrees is fine for that motor
