I bought a boat out of Hong Kong ARTR. It appears to be a Delta Force knock off. I thought I would share some pictures of it for the group. I have never seen a drive shaft like this before? It is a two piece item. One piece is the cable that has a square end that slides into tube and connects with the second piece. It really is quite interesting. Because it is two pieces the thrust gets transfered to where the prop is to the plastic washer but does not transfer to the cable part of the shaft and thus to the motor. Has anyone seen this before?? I can't figure out how to pull out the lower shaft. Even if the cable part of the shaft is completely out (had to pull the motor and take it out the that way) the lower second shaft does not come lose??
Other comments on the boat:
1. Hardware is nice. The rudder is setup neatly to kick up with out the use of a shear pin.
2. The glass work is good, but it could a use a bit more polishing in that is has small "scratches" in the hull.
3. I hooked up my spektrum radio and it worked the fist time! No esc work or anything.
4. The guy shipped it on the 27th and it arrivedin Texas on the 4th. Very good.
5. Cost was 299.00. think it was about 330 ish with shipping...
6. One slightly amusing thing is that the prop was made out of pot metel and was completely blunt. I might try that out sometime just for grins to see what happens.
7. The boat is 33 inch boat roughly...haven't broken out the ruler yet.
I will try the boat out this weekend and see how it runs.
