I have a mean Machine running Lep 4074 200KV timing at around 11.5 ? 2 4000ma 5s Parallel.. 180 ESC (seaking) .. if I nail it from the git go it stalls in about 100ft. If I take it easy, it stays running,, I suspect a heat problem. By the time I get the cover off the temps are at 130 on the motor and 113 on the esc I have the LVC disabled . I feel the problem is not in my speed control the motor was pretty hot and my cells are puffed !!
boat cutting out
Hey Jay I don't use the BEC so the RX and ESC is on there it's a Life 2 cell ( I know it has 4 cells I guess 2 are in Parallel) You know I have been running that prop so long the , #'s are wone out and I am thinking 645 but I run my struts hi ... I will check it tomorrow with the pitch Gauge , could the batteries going off on thermal overload or the motor ?Comment
May want to try turning the can on the motor. Looking at the pics it look like you may be getting air trapped in the can with having the exit so far down on the side of the motor.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
But I cannot see the motor heating up in 100ft if all is well.
It could be possible that under hard acceleration that 645 is drawing enough to overtax the ESC.Comment
Good point I will check that out thanks guys !!!Comment
Hey Chris.
Had for me to see what's going on in there lol, so I'm just going to write down a few things I would look at before the next run. If I've missed anything, please correct me someone.
1 Leo 4074/2000 if wye wind then timing 10-11,5 is ok. If delta wind then low timing in the 1-3's or 0
2 loose the small cap bank that's hanging off the ESC they are evil, solder 2-3 35v 1000uf or so on there.
3 cut the wires as short as you possibly can on the ESC
4 same goes for cooling lines, cut as short as you can
5 not sure how your cooling is plumbed, but try to cool "motor can" first then to ESC, then out. The front mount is not super important. So if you can find a short way in cooling, you are in front. The 42 prop is a good start and should be safe to run. It could of cause be a motor or ESC issue, but I would check some of the points mentioned. Even if you end up with a new motor, you should still consider the mods. So in a nut shell....Correct volts to motor, Correct timing, shortest way to power, shortest way to cooling. Correct props.Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
"Follow someone's footsteps and you will always be a step behind"Comment
Hey Chris.
5 not sure how your cooling is plumbed, but try to cool "motor can" first then to ESC, then out. The front mount is not super important. So if you can find a short way in cooling, you are in front. The 42 prop is a good start and should be safe to run. It could of cause be a motor or ESC issue, but I would check some of the points mentioned. Even if you end up with a new motor, you should still consider the mods. So in a nut shell....Correct volts to motor, Correct timing, shortest way to power, shortest way to cooling. Correct props.Comment
Ok, the TP's are a good choice. I think 4050's in the 2000kv range should be fine for what you are doing. Not really worth running a motor with problems. I don't even bother trying to fix or change bearings on cheap motors. Spend the 100 bucks and get a brand new TP.Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
You guys see my set up if I wanted to buy a different ESC what would you suggest a Etti-Swordfish ect ? I am also going to put a TP 4050 in there ( what KV suggested ) I will more then likely go to 4 cell. So any help is appricatedComment
As Far as that goes I was thinking to putting a larger water line on the input side. and maybe reduceing the water exit to cause some back preasure ? I don't know why they design the water cans with the intake & exits where they are ??Comment
