Which Eagle Tree
  • knpc
    • 566
    Which Eagle Tree
    As I invest more money in my boats I would like an eagle tree to test props and prevent damage to esc, motor and lipos. I'm not sure which one I need. It would be for a 29 titan with sv motor and esc and a 33 delta with 1515 1y and castle 240. How easy are the to use and hook up? Which one do I get?
    Thanks for the help
    Kevin
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
  • lonewolf
    • Jul 2007
    • 658
    Personally I would get the v3 hi amp version.
    Some good add ons are the brushless rpm sensor which is easy to install and easy to switch between hulls. I have a v2 which if I am correct is limited in its amperage readings. The add ons are fairly cheap. I would love a V3 now seeing I have broken the 100 amp mark. I deffinately suggest the hi amp vesrion so you can grow into it verses being limited by it... Dave
    Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
    • AntronX
      • Jul 2008
      • 333
      Yep, I just got another V3 150A unit from OSE. My first one flooded with water and burned. Definitely must have tool for fast electrics. Just keep it dry :)
      • knpc
        • 566
        Thanks, that was the one I thought, it seems worth the extra $20. Could someone describe how its wired or a picture of it hooked up?
        Thanks
        • lonewolf
          • Jul 2007
          • 658
          It is hooked up inline between the cells and esc. The addons connect directly to the unit. There is also a ower panel which will let you see what is going on at the pond(very handy) and worth its weight in parts not fried.
          • knpc
            • 566
            Thanks for the info, I'll order one as soon as steven is back.
            • ED66677
              • 1300
              that's THE tool!
              Emmanuel
