what should i put this power plant in.
  • ls1fst98
    • 859
    i have a leopard 5692 540kv motor, and a 3-16s 300a fightercar esc. what would be something fun or cool i could throw this in. i have the cf motor mount, with esc tray on top.
    A big mono
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      Df 45
      • ls1fst98
        • 859
        what about for a saw type boat...something to do something stupid with lol. if that makes sense.
          Make Total Destroy
          • Mar 2014
          • 1952
          You mean overpowering something? I've done it with success but it needs to be a hull that can handle it... Not sure which tho
          • ls1fst98
            • 859
            yes basically. just something to pull out for one or two fast passes at the lake for the wow factor. i had thought about a zonda on 12s.
              A Kv of just 540 is too low for any really high speeds. That's just around 20,000 rpm loaded, not really SAW territory. The motor is best suited for a larger gas hull with speeds in the 60s.
              • ls1fst98
                • 859
                gotcha. i wasnt sure if i could spin a larger prop. what would be the max size hull you think it could push at cruising speeds then. say 60 max, but even if it was a big hull in the 40s with an average run time.
                  I think a DF 45 like said above would be a good candidate.
