Race speeds?
  • Terry Keeley
    • Dec 2011
    • 475
    Race speeds?
    Please help a guy that routinely "lets out the magic smoke".
    What would be a true (not keyboard) speed for a well set up:
    P Mono
    P Limited Mono
    P Sport Hydro
    P Limited Sport Hydro
    Q Sport Hydro
    Thanks!
  • RandyatBBY
    • Sep 2007
    • 3915
    I will help you with what I can. In my district I race P ltd off shore, P ltd Sport Hydro and P ltd hydro the most. So hear is the speeds I run at:
    P ltd off shore/P ltd mono 49MPH to 54mph
    P ltd Sport Hydro my best speed is 54.8MPH
    P ltd hydro is all most the same possably 56MPH max at this point. Hope this helps
    Randy
    BBY Racing
    • Terry Keeley
      • Dec 2011
      • 475
      Thanks!
      Anyone know about P mono & Q Sport Hydro?
      • ray schrauwen
        • 9471
        Well, my Q-Sport hydro was doing approx. 55mph laps I THINK...??? 10 second lap = 60mph average and with some paddling around dead boats so I was doing around 13- 15 second laps approx.. I haven't actually dialed it in yet but, Friday I should know more... Hope to be there asap...
        Testing I was doing 12 second laps but, it's not fully hooked up, bouncing a tad:
        Nortavlag Bulc
        • ray schrauwen
          • 9471
          My P-mono was not the fastest and it's a bit twitchy too but, I run a 1521 1.5D Neu on 4S2P and a D/T'd x452 prop. Cells are 4 year old 25-35C and cheap HK 5800's. I use an older Swordfish 200 6S esc but, T180 would work fine. I use Zero degrees timing in a Delta Force 33 hull.
          The Q-Sport Uses a custom TP Power 4070-1250kv motor. It's a Y wind I run at 10 degrees timing. It uses a SF240 esc but, I added extra cooling and improved my cooling flow for another go with the SF200 8S esc. I might need to go to a different motor connector as the XT-150's my not be dissipating enough heat. I was warned....
          Nortavlag Bulc
          • ray schrauwen
            • 9471
            Top speed or average oval speed?
            Nortavlag Bulc
            • Darin Jordan
              • 8335
              I'd say that's a good "average" target...
              If you want to get to the top of the heap, I'm not sure what the speeds calculate to, but the heat racing time of 1:10 is currently the record, and I know that Brian regularly runs his in the 1:11 to 1:15 range...
              Darin E. Jordan - Renton, WA
              • Terry Keeley
                • Dec 2011
                • 475
                Thanks, just wondering about top speed at the end of the straight, average heat racing trim.
                • RandyatBBY
                  • Sep 2007
                  • 3915
                  This is a GPS test run max speed so it is I think what you want. The average run time on the track is a bit of a misnomer because it is just that and not a real speed that relates to nothing but the track or oval course. Though the GPS Max speed is a little faster than runs without the extra weight. But it is a good base to work of. I would be interested in a real GPS max speed of the oval boat that Brian runs for something to shoot for. I think Brian is possibly the fastest in the country with the P LTD Hydro. Come on Brian you do not have to be shy.
                  Randy
                  BBY Racing
                  • ray schrauwen
                    • 9471
                    If magic smoke is coming out, why would someone worry more about top speed rather than a setup that is reliable and will finish all heats? You can't win by speed alone.
                    Nortavlag Bulc
                    • RandyatBBY
                      • Sep 2007
                      • 3915
                      Because he is a sport runner and not a racer. I my self use it as a base line much easier than needing some one to hold a stop watch for me.
                      Randy
                      BBY Racing
                        We run in generally rough, windy conditions so we can't run too fast and still finish, but the fastest winning oval boats in Texas have top speeds recorded in racing heats of:
                        P Mono: 52-54
                        P Limited Mono: don't run the class
                        P Sport Hydro: 58-62
                        P Limited Sport Hydro: 52-54
                        Q Sport Hydro: 65-71
                        These speeds allow the racers to actually finish race heats, not set SAW records.
                        • ray schrauwen
                          • 9471
                          This asks nothing about sport running, strictly asking about racing classes. That's why I found some responses confusing is all....
                          P Mono
                          P Limited Mono
                          P Sport Hydro
                          Q Sport Hydro
                          Thanks!
                          Nortavlag Bulc
                          • RandyatBBY
                            • Sep 2007
                            • 3915
                            Oh my bad, sorry you are right.
                            Randy
                            BBY Racing
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2558
                              Not that Fluid's numbers need any validation, but these hydro speeds are spot on with what we are seeing up north. Although, 71 is a FAST Q Sport!! Only Ray can achieve these speeds with his secret wind motor.
