thrust bearing.....what's your take?
--Albert Einstein -
I can see that
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Yesway. Also the gyroscopic effect of the motor ."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
You are correct. I have finally realized (admitted to myself) that I am not a hull builder at all. So I talked to Grim and asked if he knew anyone with a Rigger for sale. Happy to say he did and I bought one of Brian's. It was run 2014 at the Nat's and I am lucky for it to be in my home in Chicago, IL now. Plans are to run at Flint, MI this spring. I cannot wait until spring.
MikeDo It Like You Mean It .....or Don't BotherComment
I have. No matter what angle the motor is at, it not going to affect it. The prop shaft angle is what will affect it. Think about it. You could face the motor backwards. It's still going to do the same thing. The prop and shaft are pushing it straight ahead. All you need is something to stop the shaft from traveling to far in the boat if you will (collet/motor) and no matter what angle you have the motor at, your going to have forward thrust dependent upon prop angle.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Very true."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
You are pretty lucky to have one of his boats.
Ray,
MikeNortavlag Bulc
Would it be more or less correct for me to think in the following way?
As said from one of the posts, if the prop is pushing the boat, that kinetic energy is transferred through out the drive line. In a typical one piece flex cable where there is a gap between the drive dog and the stinger/strut, the forward thrust then is compressing the cable ( never mind the negligible shrinkage that everyone talks) , which in turn is transferred/relayed to the collet, motor shaft, bearing, endbell, finally to the motor mount which fortunately is secured to the floor and thus pushing the boat forward.
So, if we push a car from the rear, we push the bumper or the lid of the trunk, can't imagine we will open the driver's door and push( pull) the car by the head-rest on the seat. With this logic, the two piece shaft makes most senses because you can place a thrust bearing between the stinger/strut and the prop (or without it like TFL setups) and that would serve as the rear most point to push the boat.
In light of the usual set ups, since it is recognized that the cable does shrink, no matter how little it is, the torque that is causing the shrink is still greater than the pushing force that can compress the cable, and because of that, we don't have excessive cable whip.Too many boats, not enough time...Comment
I have. No matter what angle the motor is at, it not going to affect it. The prop shaft angle is what will affect it. Think about it. You could face the motor backwards. It's still going to do the same thing. The prop and shaft are pushing it straight ahead. All you need is something to stop the shaft from traveling to far in the boat if you will (collet/motor) and no matter what angle you have the motor at, your going to have forward thrust dependent upon prop angle."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Yes Ray, The building job is soooo nicely done very talented man. Ice all around me so taking my time getting things ready. Boxed up Revolts and stuck them on the shelf. Real test is see how I do in the drivers seat. MikeDo It Like You Mean It .....or Don't BotherComment
In light of the usual set ups, since it is recognized that the cable does shrink, no matter how little it is, the torque that is causing the shrink is still greater than the pushing force that can compress the cable, and because of that, we don't have excessive cable whip.Comment
