Proboat marine grease pump stopped working?
  • shartinspartin
    • Aug 2013
    • 257
    Got the grease pump. Used it a few times and now it wont spit out any grease. The tube has grease in it... What can be wrong with it?
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    Air pocket
    • siberianhusky
      • Dec 2009
      • 2187
      Out of curiosity what do people actually do with that grease gun? Finger in a tub of grease seems easier and cheaper....
      I have one for my chainsaw, use if for greasing the tip roller, just can't see where it's used on a rc boat.
      • ENCORE MAN
        • Jan 2010
        • 891
        Some Proboat models have holes in the drive equipment into which the grease gun is inserted to lubricate shafts etc. BG
        • RaceMechaniX
          • Sep 2007
          • 2833
          There is a ball and seat that occasionally gets debris in between. The simple fix is to remove the tip and use a Q-tip to clean out the grease and some brake cleaner to clean off the ball and spring. Reassemble and it should work again.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • shartinspartin
            • Aug 2013
            • 257
            Thanks guy. There was an air pocket and it needed cleaned with a q-tip.
            I have a tub of grim racing marine grease also. I tend to use the gun more. Its easiear and cleaner to apply. Just apply and insert. Also I pack my stuffing tubes with grease. So it would be alot harder with out the nozzle.
            • bigcam406
              • May 2009
              • 236
              I just use a baby syringe filled with grease to lube the propshaft hole in the strut and stuffing tube.total cost 2 bucks.
