Aquacraft gold can o-rings
  • high-tech
    • Sep 2013
    • 331
    Hi guys, where can I buy the correct size O-rings for this cooling can. I have the 36mm red silicone o-rings and are to small in thickness (diameter)... I thought maybe grainger or mc master Carr... IDK
    Keith Geusic #677 NAMBA District 19 Seaducer Gas MONO, Aquacraft Revolt Fe30, 30in Max Cat scratch Built
  • longballlumber
    • 3132
    I bought a few of these and they seemed to work. I would highly recommend chamfering the leading edge of the motor can to aid the installation process. otherwise you will keep destroying rings.
    McMaster part number 9262K447
    Later,
    Mike Ball
    • Mike Caruso
      • May 2012
      • 940
      AQ O-rings they are different just a fuzz different. I just bought two from Kintec that look correct but I have yet to install them.
      Do It Like You Mean It .....or Don't Bother
      • high-tech
        • Sep 2013
        • 331
        I found some O-rings at Ace Hardware a lil to small but I worked with them and I got them to work. I did what Mike Ball suggested and I chamfered the leading edge of the motor can and they go on easy thanks Mike! Right on!!!
        • high-tech
          • Sep 2013
          • 331
          Battery Tray
          Hey Mike
          check it out works great and seems to help stiffen the hull
