Which cat hull from 40" to 50" will give me the most room to work with in the sponsons for a twin set up? And what kind of set up to push it for some descent speeds. 65mph. Thanks.
Best cat hull for first twin motor build
Tags: None
A carbon fiber 41" Fantasm has plenty of room in the sponsons and you can reach speeds exceeding 65mph with the right setup.37" Fightercat Shocker powered by Neu 1530 on 10S -
A carbon hull is very expensive, Have a look to a MHZ Mystic 114 http://www.mhz-powerboats.com/Hulls/...m---44-8-.htmlComment
You should look at the new Keith Bradley/Radtek 45" Cat hull http://forums.offshoreelectrics.com/...adtek-Cat-HullComment
A daytona, shocker or fantasm. I really have been thinking about building a budget rivercat twin. Using proboat stock 1800kv motors, 80 amp stock pro boat escs....would make a wicked fast 32" budget cat32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I think a Daytona would be tight but not impossible. All three hulls with the right setup have exceeded 100mph.37" Fightercat Shocker powered by Neu 1530 on 10SComment
I have a rivercat with a pair of cheapo $15 turnigy outrunners and t120's on 6s and the thing flies!! I still own it as its great fun and touches 70mph on X445's Personally I thinks it's a great hull and much better than a Daytona (which Ive also built)Comment
I built a Daytona twin with turnigy 3659 edf motors 1900 kv, T180's, and octura x447's. 3/6" flex cable, aeromarine couplers, and 6s1p Turnigy 60c 5000's. It has carbon/kevlar inlay, and Kintec 110mm struts, yesterday it ran 79.23 mph. Fastest yet. That was a rock solid run, well all the runs were rock solid. Temps after running a complete pack thru it were around 115 deg. on everything. This is a budget build. $50 motors, $77 dollar esc", $35 batteries. and the hull is only $76 from fighter cat.Last edited by spadforme; 07-15-2014, 08:53 AM.fighter Cat Daytona twin-6s1p--90.1 mph
Genesis-TP4050,6s1p--74 mph
HK Apparition twin-4s1p--60.2 mphComment
I think the shocker or fantasm. People have gotten some really nice speeds with both. Me personally I would go fantasm with 2000kv 4082 leopards and start on 4s, with swordfish 220a/300 escs. There you have room to grow and can run lower cell count to get a feel for things.Comment
Man a rivercat would be so cheap and fast to do a twin. Two cheapo motors, two sea king 120's and two 3s packs run in series to be 6s feeding both motors...that thing would fly.Last edited by kfxguy; 07-14-2014, 06:31 PM.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I built a Daytona twin with turnigy 3659 edf motors 1900 kv, T180's, and octura x447's. 3/6" flex cable, aeromarine couplers, and 6s1p Turnigy 60c 5000's. It has carbon/kevlar inlay, and Kintec 110mm struts, yesterday it ran 79.23 mph. Fastest yet. That was a rock solid run, well all the runs were rock solid. Temps after running a complete pack thru it were around 115 deg. on everything. This is a budget build. $50 motors, $77 dollar esc", $35 batteries. and the hull is only $76 from fighter cat.fighter Cat Daytona twin-6s1p--90.1 mph
