fiberglass 37 " daytona running wet
  • urbs00007
    • Jun 2011
    • 826
    running this boat with 4082 1600kv. on 6-s. m445. runs wet with strut flat or 1/8" off table, 65mph fastest 58 mph slowest. fastest was m445 flat to table strut ,but lower runtimes with a little heat. 58 - 60 mph 1`/8" off table much better runtimes cool electronics. then i read up on running surfaces on cheetah tiqueman redid ride pads. this is what i have. is it bad and how do i fix it?005.jpg
  • Idontswim
    • May 2014
    • 147
    Have you tried angling the prop up a little? Batteries to the back?
    • urbs00007
      • Jun 2011
      • 826
      when strut was flat to table we tried angling the strut a little with no result. after raising it, we have not tried that. batteries are back as far as i can go balance point is 3/4 back on the 2nd sponson.
      • urbs00007
        • Jun 2011
        • 826
        running wet
        balance point is at 25%. moving back more will require relocating servo and battery tray which is well glued.
