water tension
  • ls1fst98
    • 859
    #31
    All you did Darryl was copy and past somebody else's stuff. Start from the beginning and explain in it in layman's terms. Keeping in mind that we are talking about boats and not what water does to to a structure, like a bridge sitting stationary in a river.
    but they all involve movement of water, one has water flowing around it, other is moving on it. flow is flow. its all fluid dynamics.
    • cybercrxt
      • 2909
      #32
      Just run your hull in slick glass water and radar it...then scuff the bottom, and rader it in the same conditions. I bet the results will speak for themselves. Also, if you do this on an o/b tunnel, tell me how much better the handling was and how it didnt do stupid odd things with the bottom scuffed.
      • darryl whitman
        • Sep 2012
        • 535
        #33
        Thanks cybercrxt
        • Fella1340
          • May 2013
          • 1035
          #34
          I could see a boat "sticking" to water better with a roughed up surface, going faster not so much.:)
          • Mike Caruso
            • May 2012
            • 940
            #35
            Or install a Data Logger like Eagle Tree. BTW my revolt hull IS scuffed. You need something to do A-B-A testing. Me I was done wasting time and the ET has saved me TIME on the water looking for answers.
            Do It Like You Mean It .....or Don't Bother
            • darryl whitman
              • Sep 2012
              • 535
              #36
              you know , some times you gotta step outside of the box we all live in , if not we all would still be in the stone ages,
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                #37
                Lads, you are "beating a dead horse"....As noted others have stated scuff or lightly sand.
                Douggie
                • flraptor07
                  • Aug 2013
                  • 2451
                  #38
                  So what did you see with the ET ? How much of a gain with a scuffed hull ?
                  • Fella1340
                    • May 2013
                    • 1035
                    #39
                    I think instead of scuffing I will just glue the sandpaper to the hull, wet sanding paper of course!:) I could always sand blast to, a fellow has to keep his options open!:)
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #40
                      From what I've been told that probably won't work because the sanding should be done paralel with the hull
                      • Fella1340
                        • May 2013
                        • 1035
                        #41
                        Just having some fun:-) I am sure the benefits and pitfalls with however you choose to finish your boat. Personally, I will leave mine nice and shiny.
                        • flraptor07
                          • Aug 2013
                          • 2451
                          #42
                          I saw that, just thought I'd let you know that little bit of info...
                          • tlandauer
                            • 5666
                            #43
                            Two strips of 1000grit would make nice ride pads on any hydro or cats! Saves the trouble of blue printing!
