Water cooling problem
  • Jlov
    • Nov 2013
    • 825
    I am having a problem with water coming out my water outlets. Now I know how I just burned up my Swordfish ESC. I just ran my Popeye and noticed I didn't see water coming out either outlet on sides of boat. If I flush boat in back yard using my engine flusher water comes out both sides of boat. If I blow thru both water tubes that bring water in thru transom air comes out both water outlets. If I blow thru both nipples on rudder air comes out holes on bottom of rudder. So what could possibly be stopping water from flushing thru everything when boat is actually running in water?.... Any suggestions please. Thx Jeff
  • revoltrunner
    • May 2014
    • 646
    rudder water pickups aren't great and those holes
    in your rudder look awful small.
    • Doug Smock
      Moderator
      • 5272
      The holes in the rudder should look like this.
      Work on that rudder a bit with a round file and see if that won't work for you.
      Sorry you lost a ESC.
      Who makes that rudder?
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • grsboats
        • Jul 2012
        • 975
        or add an auxiliary water pick up.the lower water pick up on my rudder was added for better cooling. Gill
        GO FAST AND TURN RIGHT !
        www.grsboats.com.br
        • Jlov
          • Nov 2013
          • 825
          It's Kintecs rudder dual pick up rudder. Used this type of rudder on last Popeye and it worked fine. If I put bottom of rudder in my mouth and blow air comes out the two nipples at top. Does anyone know who else makes a dual pickup rudder? Thx Jeff
          • tlandauer
            • 5666
            Gill, what is that brass fitting near the strut bushing for? Looks cool, is it for lubrication?
            • Jlov
              • Nov 2013
              • 825
              Actually Doug thatsba Speedmaster bracket I have on Popeye and just noticed your link is Speedmaster products and they have a rudder I can use. Thxxxxx Jeff
              • tlandauer
                • 5666
                Jeff, I had the same exact problem with TFL's single pick up on my Popeye, now I know why the motor was always hot, everything I did on land indicates good flow, but once it is in the water, there is very little coming out of the outlet, I just checked my pick up holes, it is a bit longer but not by much, guess I have to elongate it too. BTW, the only other rudder with dual pick up is a Speed Master, huge rudder though. I had to cut it down for my Lizard Xtreme.
                • Jlov
                  • Nov 2013
                  • 825
                  Ok thx Tim that helps. Never checked my other one that was on the first Popeye. It probably was doing same thing as my motor in that one was always hot to. I have the Speedmaster rudder that came with the bracket I have on there but it's a single pickup. I'll just have to order the dual pickup one. Thx Jeff
                  • revoltrunner
                    • May 2014
                    • 646
                    OSE has a good selection of hull mounted pickups.
                    they work a lot better and shorten up your lines too.
                    http://www.offshoreelectrics.com/pro...ng+Accessories
                    • SloHD
                      Slow Electric Addict!
                      • Apr 2013
                      • 337
                      It's a hydroplane, he could only use the transom mount type, which would cause unnecissary drag.
                      Jeff just get the speedmaster rudder that was intended to be used with your bracket in the first place.
                      • IRON-PAWW
                        • Oct 2011
                        • 314
                        That looks an awful lot like the rcbb rudder..... which did indeed also turn up at Kintec as well. If I remember right..... some people trying those rudders out on hulls other than those they were designed for, found that they had to be very careful the pickup holes were actually submerged during runs. Some people were highly suspicious they weren't. Just a thought.
                        Had that rudder on my Zonda cat for a while. Picked up water ok. I know RCBB does nice dual pickups. But the speedmaster ones are good kit too.
                        PERTH AUSTRALIA
                        • urbs00007
                          • Jun 2011
                          • 826
                          second part of your response makes sense. first part not so much. what do you base this statement on?
                          • urbs00007
                            • Jun 2011
                            • 826
                            i would contact kintec and ask them to get those pickups modified. and post their response. forums are a good way to warn potential buyers of garbage hardware. just make sure you have gone through every inch of you your water system to make sure there are no blockages. there is no need for this kind of mistake in manufacturing. why change something that has worked great for all these years.
                            • revoltrunner
                              • May 2014
                              • 646
                              I am new to fe boats but have been running nitro boats since the mid 70s.
                              keeping the cooling system as short as possible has always worked the best.
                              adding extra tubing to get back to the rudder plus the length of the water port
                              inside the rudder makes it that much harder for the water to flow through the system.
                              jeff said he blew air through the rudder. if he would hook the entire cooling system
                              back up and try to blow a mouthful of water through it I think he would be surprised
                              at how much force it really takes. I'm not saying rudder pickups don't work,but having
                              a shorter cooling system works better.
                              I found this thread interesting
                              http://forums.offshoreelectrics.com/...=water+cooling
