I am trying to respond to this thread:http://forums.offshoreelectrics.com/...tor-shaft-bent
by sending him the rotor from my burned 1800kv AQUACRAFT motor. Motor died on the first run, total run time was no more than 4 minutes, not over worked: it was in a MG, M445, 4s2p.
However, when I took the rotor out, the laminate is black, I could tell it was from the burn ofr it's supposed to look like that---never looked inside this motor. Also the ends of the magnet seemd a bit yellowish, there are numbers writing on the laminate, also the laminate is not what I would call good quality work, in the front there is one tiny spot that was not covered.
Should I offer this or I will just give him more trouble??
