Aquacraft motor shaft bent
  • Bking1340
    • 23
    Have posted this in the Aquacraft RTR thread
    Good day all
    I have recently ordered a Aquacraft Revolt 30 from Omnimodels.
    The problem I have is that there are a lot of up/down and sideway movement at the coupler/flex shaft – The movement can be seen when turning the prop by hand and the motor mounts are also moving around.
    I thought it was the aquacraft flex shaft or coupler, but I ordered a upgraded flex shaft and octura coupler from offshoreelctric (Received yesterday). The same problem.
    So this morning I installed my receiver and removed coupler/flex shaft from motor and gave it some throttle – When giving about 10% throttle, you can see that the motor shaft are wobbly/running off center.
    The alignment between motor and stuffing tube are 100% - the upgraded ose flex cable slides in like butter.
    Any advice?
    Have just received a mail from hobbico, that I can send the motor back for a warranty inspection, but a similar size package (ESC) cost me $55 last year to send to the states from South Africa (Normal 5 weeks shipping). Shipping from South Africa is very expensive. New Aquacraft motor + shippment to me is $79.
    I don`t see any loose shafts available for the 3656 1800kv motor.
  • tlandauer
    • 5666
    If shipping is THAT expensive, get a new one, I have never heard or read anything like that before, sorry to hear your problem.
    Having said that, I had a brand new 1800kv motor that burned during the first use, about two or three minutes into running, don't know why, the wires exting the rear endbell shorted out, I can take the rotor out and send it to you, if you can wait. I posted the question on the other thread just so I want to make sure it will work, but no one has answered my question.
    http://forums.offshoreelectrics.com/...use-that-rotor
    If it works, you don't have to pay postage, I will send it for free.
    • TheShaughnessy
      • 1431
      It will work, assuming the rotor is the actual problem.
      • Bking1340
        • 23
        Hi tlandauer
        Thanks for the effort, but luckily Adam from Hobbico exchanged a few emails with me and he will send me a complete motor with water jacket installed from another hull.
        If something goes wrong, I will press on your button.
        Thanks again for the effort.
        • tlandauer
          • 5666
          Originally posted by Bking1340
          Hi tlandauer
          Good to hear!
          Good luck and happy boating!
          • tlandauer
            • 5666
            Thanks!
            • fwlbp
              • May 2014
              • 68
              Bking, did you receive your new motor and get to maiden it yet?
              • Bking1340
                • 23
                No - Hobbico have send it on the 12th, don`t know what shipping they have used. But standard shipping normally takes 3-4 weeks. Hopefully it was priority mail which will take a week and a 1/2.
                Will let u know.
                • Bking1340
                  • 23
                  Have just received my motor with cooling jacket - no more wobbling motor shaft. Flex shaft/motor shaft are running straight and smooth as butter. In the stupid process of balancing/sharpening my stock prop.
                  Will hopefully maiden it this weekend.
                  • jjohn581
                    • Jan 2011
                    • 33
                    I had a good experience with Hobbico on a motor and esc that was bad on Motley Crue. They sent me replacement motor, esc and water jacket. Great customer service.
