So, I decided to take a chance on one of these.....
http://www.hobbyking.com/hobbyking/s...rless_ESC.html
So, it does say they are only to be used with 2 pole motors unless you upgrade the firmware.......
"Note: Standard software is suitable for 2 pole motors. Customers using 4 pole or higher should use the 4 pole firmware set under files tab and set acceleration to low."
So, to do that I need one of these (out of stock)....
http://www.hobbyking.com/hobbyking/s...dProduct=51180
So, when its back in stock, I'll get one and update the firmware.....
So, I did by this ESC "used" and other than missing the decals, it appears to have never even had connectors soldered on it.....
So, I soldered connectors on it and it operated fine using an AQ 1800 Kv motor (just to see if it powers up)....
So, this thing is massive! See pic with Turnighy 180 for reference......
So, for the $35.00 I spent on it (shipping included), we will see what eventually happens..
