Hi!
I've got a Rocket 26" which i ran a TP3630 2100kv on 4s with a Swordfish 120A controller and a X642 prop. No matter how loose it ran, it drained a 5000mAh battery in about 4 minutes. Thinking the motor was a little bit too small, i replaced it with a TP4040 2200kv, then the ESC burned. In my quest for a new ESC i came across a Castle Hydra ICE200 HV with a 75% discount. I know they a discontinued, and a bit overkill for a rocket 26, but i went for it.
Now, with the hydra, I'm getting 8 min 45 sec runtime with the same drive line and batteries! I was just testing so i did not run full throttle all the time, but still, it is a really big difference. Only thing i changed was swapping the teflon liner with a brass tube.
I know there is a few variables here, but, could it be possible the Swordfish 120 was faulty? I've been told that a worn teflon liner can cause quite a bit resistance, but can it cause a 50% lift in average amp draw?
And a last question: How does the ESC rating work? The hydra is rated with 50V and 200A, is that another way of saying it has got a 10000W rating, or is it 200A no matter how many volts you are feeding it?
Thanks,
Oddbjørn
Thanks,
Oddbjørn
