Can anyone help program this esc.
Need help programming my aquarcraft 60 esc
Tags: None
What is it your trying to do? There aren't really any programing options on that esc. -
If you are having problems getting the Aquacaft ESC to arm with your radio, you probably have to fiddle with the neutral throttle setting. This is the most common problem people new to this ESC have. So if you are getting a constant beeping when you plug in the battery and turn on the transmitter, play with your throttle trim (or sub trim) until you get a single beep. Then pull full throttle and hold until you get three rapid beeps. Then you are good to go. In some instances (depending on the radio) you may have to do throttle reverse.Mike Chirillo
www.capitolrcmodelboats.com
