The search for leaks..
  • nicklanigan
    • Dec 2013
    • 7
    Anyone got any great ideas on searching for leaks - I've floated my boat in a pool, pressure tested the cooling system, but I'm still getting a bit of water in every run.
    It's not a huge problem, just annoying.
    It's a ML Boatworks GP400 built by me.
  • champion221elite
    • Jul 2013
    • 216
    Water is coming up your stuffing tube. Make sure you put a piece of heat shrink over the joint between the strut and ferrule. This will help keep water out. Also, use a small piece of silicone water line where the stuffing tube terminates inside the hull. This is where the flex shaft exits the stuffing tube. A small piece of water line here will help keep water out of your hull.
    • nicklanigan
      • Dec 2013
      • 7
      Thanks very much for the advice. Seems the only possible culprit, so will make the changes.
