40,000 rpm........what's the problem
This topic is closed.
  • Doug Smock
    Moderator
    • 5272
    #181
    Yes, they confiscated my gear. But, that's why I have it. Too many times I've seen guys move weight forward to keep their boats on the pond in less than perfect conditions. Not a good idea, bad things happen. However, if the weight is added right at the CG.
    Strut adjustments aren't always the way to go, especially in heat racing. Conditions can change quickly and if you're an idiot like I am and race 6 or seven classes, there just isn't time. It takes only seconds to add weight before you tape up for a heat and you haven't changed the set up that you worked hard to get just right.
    Just my .02 FWIW fellas. By all means do what works for you!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Doby
      KANADA RULES!
      • 7280
      #182
      Remember when this thread was about RPM???
      Grand River Marine Modellers
        Jay: I understand what you're saying in regards to lift, but would you agree that lift is a function of hull design and therefore can be addressed at the bottom of the hull, topside, drive angle, etc?
        Travis: If gravity is what's keeping your boat on the water, what's keeping planes in the air?
        Air. Lift that is greater than the force of gravity. Think we learned that in third grade. Air and water arent the same thing. Think we learned that even earlier than third grade.
          Well it's still filled with good info and some funny, foolish stuff too :)
          • keithbradley
            • 3663
            #185
            I think that's pretty reasonable, and again I am well out of my league if we're comparing heat racing setups, I'm sure.
            I haven't suggested that there is no difference in comparing boats of different weights. What I did suggest is that the statement "you need the extra weight to keep the boat on the water" isn't true.
            As a diplomatic measure I will say "maybe some people do". I still believe that if the boat won't go a given speed without the weight (remember I'm talking about a boat that won't stay on the water as a result of increased speed, not one that is running circles in race chop), the setup is off. Adding weight to a boat (increasing the overall weight, not changing the CG) to correct an issue that is only experienced when speed is increased is a Band-Aid for another problem that is not being addressed, whether that problem is hull design, drive setup, rudder setup, props used, etc. Can we agree there?
            There is another element that Mike briefly mentioned in regards to heavy, fast boats...when dealing with extreme speeds and heavy boats, people REALLY DO take intentional steps to keep a build as light as possible, while accomplishing what the builder set out to do (hull integrity, power, etc.). Part of the reason is of course efficiency, but much more importantly (IMO) is the energy a boat carries in a crash. A 30lb boat at 100+ can be absolutely devastating, even when built to be extremely strong. I once did the calculations to compare the energy of a 25lb boat at 120mph to rounds shot from pistols, shotguns, and rifles and you might be surprised by how they compare. It is unreal just how much power is at our control in some of these boats.
            www.keithbradleyboats.com
            • keithbradley
              • 3663
              #186
              Ok, Gotcha. Carry on then.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2558
                #187
                While we are on the lift subject (sorry for off-topic kfx), I'm starting to think that the geometry of most of the hydro hulls we run have too much lift. I think Brian Blazer was onto this with the vents on the whiplash. They seem to reduce lift by creating more flow area 'out' than 'in' (i.e. less pressure trapped underneath). The faster we get these FE's, I think we need to start making geometrical changes to reduce lift, and then require less weight/trimming to offset the lift. Just thinkin outloud after a few cold ones.
                • Chrisg81983
                  • Jul 2011
                  • 1556
                  #188
                  It always seems to amaze me how people jump on the people who can really make a difference out there. People really need to realize how a boat works, and how it ends up staying on the water. To be honest in a saw setup weight is not the thing that makes it happen. If adding weight to your boat solves your problems you overlooked something else more important , and its just a bandaid. So for people that can't come withing 50mph of what others do they need to back down and listen and stop trying to teach. My fastest best running boats were the lighter ones. Hmmmm get that the only time i added weight was to correct a wacked out cg on a boat that was built wrong by a person who didn't get it. There are many things that come intonplay that makes a good rumnig saw boat and i promise its not weight. Now I am going back to being a lurker c ya.
                  Oh and I can't speak for anything but SAW rules might change for oval but I am smart enough to leave that alone and leave it to the other that do know
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    #189
                    Air and water are not the same, but nonetheless some analogies can be drawn from this. If a plane generates too much lift, they don't add weight to keep it from going into the stratosphere, they alter the characteristics of the lift. Personally, I tend to run heavier batt setups in boats, simply because I was sick of straining packs and I wanted some room for error. It also to an extent did help keep some of my boats on the water, but that isn't to say it couldn't have been achieved via setup and aerodynamics, but those get more complicated with very fine tuning after a certain point, and the slightest gust of wind or wave in the wrong direction seemed to negate any influence they had. I personally think it's a fine line between the two that we are chasing, but I think most setups have all the weight they need with the motor/batts selected appropriately for the purpose, beyond that it's tuning and balancing it out.
                    My private off road rc track
                    https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                    • Doug Smock
                      Moderator
                      • 5272
                      #190
                      Yes and no.
                      Hydros, Sport Hydros, Monos, Cats, O/B Tunnels all have their own issues we have to overcome as we push them to the next level.
                      And to complicate it further. IME with monos, things change with about every 10 MPH of speed once you get up into the high 60s low 70s.
                      I like what Kentley Porter told me in E City a few years ago. He said, "I finally threw all of the theory out the window and started doing what works" Kentley could set a record with a 8' 2x4 if there was a class for it. I get tired of typing his name.
                      Yes the power in some of these boats is incredible. I have broken my fair share. When you get into the upper 80s they don't just hit the pond once! LOL And if they stuff. We have precious few attempts to get the work done.
                      Again, do what works for you fellas.
                      I'm going to leave this for the resident experts now.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                        I'd like to see you build a fantasm. Cut the weight as much as possible (say get it to weigh 5lbs, not possible I know) and see if you can hit 100mph with it. Then build one at normal weight and try again. Come back and tell me how your test went. I'm no dummy, i dont even have to do it to tell you what's going to happen. You have to have a certain amount of weight for anything. It's a balance.
                        To the person about the plane, I'll say it again, it's not the same thing. You have controls on a plane that you can change all sorts of things on the fly. On these boats, we do not. If we had remotely adjustable struts and a remotely adjustable spoiler on the front, you could keep the lightest boat on the water provided you can adjust things fast enough at speed without making it submarine or fly of the water. So ....as an easier fix, some times the faster you go, you may need to add more weight. Say or think whatever you like but the fact of the matter is most of our boats are heavy anyway once all the gear and electronics is installed so you may be heavy enough to not have to add anything anyway. Once things like batteries start getting even lighter and motors/esc's get lighter, you'll see that you'll have a harder time keeping it on the water.
                        • Rocstar
                          Joel Mertz
                          • Jun 2012
                          • 1509
                          #192
                          You must have a lot of experience on this subject. At what speed are you personally having to add weight to your SAW boats? I haven't had to add forward weight on any of mine yet. My Fantasm did blow over, but after a stinger and cg adjustment it was flying level again...but that was only at 93 mph... I assume you're having issues at much higher speeds with yours.
                          • kevinpratt823
                            • Aug 2012
                            • 1361
                            #193
                            When a boat comes off the water, 9 times out of 10 it was air, not water, that did it. That is why we call it a blow over. So yes, aerodynamics is very relevant, just so happens a plane operates solely on aerodynamics, of course they can be adjusted on the fly.
                            I also used the term "analogy"
                            n. noun
                            Similarity in some respects between things that are otherwise dissimilar.
                            • TheShaughnessy
                              • 1431
                              #194
                              Aerodynamics are relevant.
                              My boats aren't fast enough to argue about so ill be the grammar
                              police.
                              Very is a crapy verb so I don't use it
                              Plural noun uses plural verb to be
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #195
                                I'm going to have to disagree on the Air and water not being the same thing, from a aerodynamic standpoint Air and Water are the same. I.E. Water tanks and dye to test flow chartaristics on everything from Cars to Planes to Boats to Semis. All the same principles apply.
