Pt stealth 30
  • JimClark
    • 5907
    Pt stealth 30
    Most likely getting a Phil Thomas Stealth 30 to run as a spec hydro. Looks like most are using the Aquacraft UL-1 motor. I don't have one of those but have plenty of Proboat 1500's anyone tried using a PB1500 in the PT stealth 30?
    Billy Graham
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1518
    The Dynamite 1800kv seems to be the ticket lately. It's the "stock" motor from Proboat now. The newer AQ UL-1 motors are not up to snuff.
    You can use the 1500 kv Proboat motor and get reasonable performance, but expect to get your butt kicked in a competitive format.
    • ray schrauwen
      • 9471
      Ray, do you think the AQ 1800kv is up to snuff?
      Nortavlag Bulc
        • 9488
        Could you use a prop with much more pitch to get similar results as the UL-1 motor ?
        • longballlumber
          • 3132
          Regarding your question Jim, I am not confident 1500kv is enough RPM to keep up with an 1800 or 2030. You would need to run a prop in the 48-50mm area to get any speed. That would be a huge prop for that boat.
          However, I have successfully campaigned an AquaCraft 1800 in my stealth for more than a year. The boat runs very well with the 1800kv.
          This is a video from nearly a year ago, first race of the season. It's the Orange hull that goes way wide at the start, but still jumps LOL
          • Darin Jordan
            • 8335
            I'm not sure how other's have faired, but my Stealth has some issues getting up on a plane from a stand-still... just wouldn't do it last year.
            I need to verify that the ESC Startup power was set appropriately to provide the "burst" at startup to jump it out of the water.
            That was running the AQ2030 with a Hydra 240 ESC and a 440/3. This is the same setup that I was running in 2012 at the Nats and doing fairly well with. I think it's also the same basic setup that Tyler is running with his. He told me he has to hand-launch the boat.
            I've been thinking that a bit more prop and a lower KV, more torque, setup might work well with this hull, which IS fairly heavy to start with.
            Incidentally, the most recent Dynamite 1800KV (Pro Boat) motors are QUITE CAPABLE pieces... the motor leads have been upgraded to 12-awg, and there have been some other design updates that increase it's efficiency and power. The 1500 has been updated similarly. Inline update, so same part numbers, etc.
            Darin E. Jordan - Renton, WA
            • JimClark
              • 5907
              looks like I might have to put a 1800kv motor on the list of items to acquire.
              Thanks all
              Jim
              Billy Graham
              • ray schrauwen
                • 9471
                Thanks for the update on the PB motors Darin!
                Nortavlag Bulc
                • jcald2000
                  • May 2008
                  • 774
                  Where is the solder join for the 12 Ga. leads, next to the stator?
                  • JimClark
                    • 5907
                    Ok I have a Stealth 30 on the way to me and am going to use a Dynamite 1800KV and Turnigy 120 ESC. Need some recommendations for props
                    Billy Graham
                    • JimClark
                      • 5907
                      Here it is
                      Billy Graham
                        • 9488
                        Jim that looks great!
                        maybe a x645 ??
                        • ray schrauwen
                          • 9471
                          Is there any lead in it Jim? Nice boat!
                          Nortavlag Bulc
                          • Rumdog
                            • 6453
                            M445 is a good starting point
                            • JimClark
                              • 5907
                              Not sure Ray I will have to ask Phil Thomas
                              Billy Graham
