Can someone tell me how to check the center of gravity on my Daytona hull. My build is nearly complete and someone suggested my motors may be to far forward and that my COG may be off. Thx Jeff
COG Help
you want it to be roughly 30% of the length from bow to the end of the ride pad at the stern. not length over all. take a round dowel and set the boat on it and put all your running gear as it would ride including hatch and see how it balances.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/ -
yes you should always try to set the motor as far back as possible. make all the fixed stuff as far back as you can within reason and use batts to adjust cog. pic of where your motors are?HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/Comment
Yes found old thread on how to find COG. I have two 5300 4s packs in hatch on and COG is at 37%. But that was based on full 37" hull measurement. If I measure it from tip of sponson to end of ride pad where stingers mount up then COG comes out to 30%. So am I ok? Thx Jeff
Here ya go
image.jpgComment
sounds like you should be good. they do look far forward but if its at 30% then i dont see a need to move anything.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
I'm sure adding weight to boats is a no no but I'm not racing. I just run these out on my boat for fun. I think if COG does end up being off a little I will just counter it with some lead weights in rear rather then have to go all through removing epoxy and mounts. Or is that really not a good idea?Comment
Adding weights is def not a no no. I've done it with success
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
