[QUOTE: Tlandauer;557755]May I ask you what eaxactly you mean by that statement: that you installed a cap bank or you pulled the old one out and replaced a new one, just curious. I put cap banks on many of my Seaking 120A ESCs without any problem, but I am thinking putting one on my AquaCraft ESC, but if it will invite the same result, then I won't bother.
Thanks![/QUOTE]
Hi T.L
The 60A AQ ESC from my ul-1 was due for a cap upgrade, cause the cap looked puffy, so I ordered some from kintec for it. I verified the polarity on the old & new caps, then snipped the leads on the ESC cap, flush with the cap, so I had good leads to work with.
I slid 2 small cable stops over the existing leads, then slid three new cap leads into the cable stops & snugged the set screw in the stops up for a solid connection. I set it on gthe deck outside, plugged in a 3656, ESC & 2x 2s 5000mah packs. Well 5 seconds later it erupted in smoke & flames
Idk what happen or why, I read a ton of threads on running multiple caps on the 60a AQ, a ton of people recommend it. I guess it didn't want to cooperate. It was a hell of a fire though, glad it wasn't in a boat
Thanks![/QUOTE]
Hi T.L
