cheap 200A brushless esc
  • Avanti
    • Nov 2007
    • 1280
    not sure how good it would be but as bad as CC hydras are getting this might be ok, I had great luck with the 30A mystery esc in my hydromite.
    $52 shipped might be worth a shot
  • kburrows
    • Mar 2008
    • 547
    how do you waterproof these things? thats my only concern.
    • J Solinger
      • Apr 2008
      • 197
      Generally you can just spray your electronics with this stuff and it will be water "resistant":
      http://www.offshoreelectrics.com/pro...hp?prod=corr-x
      Even if a person can use this esc to replace a 120 amp unit it's a heck of a good deal.
      Joe Solinger
      • kburrows
        • Mar 2008
        • 547
        is that how CC waterproof their esc's? with corr-x. is there another method. My personal favorite esc is the SV one because its sealed so good.
        • Mich. Maniac
          Banned
          • 1384
          The product may be worth the price but watch out for the sellers feedback rating. I know some people are idiots on ebay but I still stickk with sellers over 98%
          • ReddyWatts
            • 1711
            Previous thread about the new Mystery controllers.
            http://forums.offshoreelectrics.com/...hlight=mystery
            ReddyWatts fleet photo
            • Mich. Maniac
              Banned
              • 1384
              New thread about the new mystery controllers.
              http://forums.offshoreelectrics.com/...ead.php?t=4351
              Sorry Reddy Watts. You know me. I had to:)
              • J Solinger
                • Apr 2008
                • 197
                I don't know if it's the same product, but it is the same idea. Coat your electronics with this stuff and you should be safe from the usual moisture that gets in.
                Joe Solinger
                • Avanti
                  • Nov 2007
                  • 1280
                  obrien was told by CC that they have some kind of silicone sealant on their esc they are water proof to 100 feet fresh or salt water, but if you try to opperate the unit while submerged it will be toast.
                  • ReddyWatts
                    • 1711
                    hey MM I like these Mystery controllers, but plan on buying one from a different supplier, since Steven has not started selling them..
                    HiModel GX Seires 200A 3-7S Brushless Electric Speed Controller Type GX-200A-OPTO from manufacturer HiModel, in category Brushless Speed Control (BL ESC) - Air/ Helis, Electric Speed Control (ESC).
                    • ghostofpf1
                      • Jun 2008
                      • 392
                      That looks just like the hi-model unit with different colored shrink wrap
                      Ghost
                      • J Solinger
                        • Apr 2008
                        • 197
                        I have been using a 3m product. It's just refered to as a dry silicon. This may be more like wat CC uses.
                        Joe Solinger
                        • video200
                          • 837
                          il prob be baned for this. but i have that wery contoller and it works great. it even out preformed my hydra 240. as the hydra crashed and burned on elite 5c 4800. on a 9XL. X640 in my drifter S and this cheap crappy mystery controller still runs with the exsact same setup.
                          • Avanti
                            • Nov 2007
                            • 1280
                            it is not a spray they use, hopefully obrien will chime in here as he is the one who talked to them.
                            Thanks for the report Video200, I might try one out for grins
                            • ED66677
                              • 1300
                              I have the 80 amp one and waiting for a 100 amp (22$ shipped!!!), I made a cooling plate for the 80 amp with a 3mm aluminium sheet and a piece of 6mm plexiglass in witch I routed the water circuit 3 or 4 mm deep, the cooling plate is glued to the ESC with silicon and the rest of the ESC is waterproofed with the same silicon.
                              Some people said the silicon would attack the PCB or some components, but some ESC's on the market are made the same way(Graupner 80 amp brushed ESC), certainly different type of silicon used but... it worked for me! Some of the new polymer glue available on the market can do it as well.
                              BTW, I pulled 95 amp burst from my 80 amp one!!!
                              The problems I see using conformal coating (I work for the US company that makes the top automatic dispensing system for conformal coating and been in this business during several years)...
                              - difficult to repair if needed
                              - difficult to apply in narrow areas (multi layer ESC) knowing that heat exchange surfaces (top side of FET's) should not be coated!!!
                              - many type of coating material on the market that are mostly not good enough for what we (in FE) expect, even if several layers applied!
                              Hope this help.
                              Emmanuel
