Removable stuffing tube?
    Need some ideas, thoughts, comments.... Am I wasting my time? I was thinking about epoxying a larger piece of tube in the hull and silicon the smaller tube into it..... Yes.... No.... Maybe so?
  • Darin Jordan
    • 8335
    Originally posted by kfxguy
    Red some ideas, thoughts, comments.... Am I wasting my time? I was thinking about epoxying a larger piece of tube in the hull and silicon the smaller tube into it..... Yes.... No.... Maybe so?
    That's how a lot of us do things... go for it!
    Darin E. Jordan - Renton, WA
    • marko500
      • Aug 2008
      • 861
      I've gone to this on newer builds and have been converting older boats over to it. Works great, makes replacement, bending or adjustments easier too. I was a bit worried about leaking and the stuffing tube twisting inside the larger tube under load. But so far after several years neither has happened.
        So should I silicon or loctite it?
          Neither, it simply isn't needed and using a glue limits the adjustments possible. Fifteen + boats with this method and never a leak between the two tubes nor any twisting. Most were "J" bends.
          • ray schrauwen
            • 9471
            +1 With Fluid. Best way to do it on cats & Hydro's. Never tried on a mono. No glue needed as Fluid says.
            Nortavlag Bulc
              One more question. How long should I make the "hull" tube? Pic may be helpful too if someone doesn't mind. Thx
              • marko500
                • Aug 2008
                • 861
                Mine are all a little different, depending on the angle the tube exits the hull. But mine are about 2" give or take.
                • Darin Jordan
                  • 8335
                  Here is one example that worked for me on my Pro Boat Mystic 29 "Minus-Two" with .078" Wiredrive.
                  I've also cutoff the outside tube flush with the hull and extended the inner tube a little further out.
                  On my new N2 Cat (second picture), I'm going to have to use something (silicone, etc) to hold the smaller second tube in place. There isn't any bend there to hold it and it slides pretty freely in and out. Will be even worse if I try a .047" wire.
                  • Fella1340
                    • May 2013
                    • 1035
                    Great idea.
                      Excellent. Went picked up some 9/32 brass tube on my lunch break. I'm gonna try to get some stuff done tonight.
