has anyone done a post on making right angle bullet connections? do you solder wire into hole on side of bullet and then shrink wrap and trim excess shrink?
90 degree bullet connectors
The 5.5 bullets with the cut out work good for doing a 90 degree if needed,
Like these.http://www.hobbyking.com/hobbyking/s...dproduct=43311 -
I also put a piece of bent 5/32" brass rod in where the wires would normally fit to give it mechanical strength & a better solder joint.See the danger. THEN DO IT ANYWAY!!!
