sf300 pro plus issue
  • forescott
    Hopelessly Addicted to RC
    • 2686
    Ok, have a big mono that I set up a while back with a castle 2028, to run on 10s. Hasn't been in the water yet, but everything has been hooked up. Finally after months, I got a chance to bench test it, but can't seem to get the motor to spin. The esc gives the two beeps when I turn it on, but no throttle response. Using a tactic radio. The radio is bound to the receiver correctly and the steering works. I also have the programming box. I tried it with both auto lipo detect and set it for 10s as well, but still no response. tried reversing the throttle and spinning the throttle trim button back and forth as well. ?????????? I don't have any experience with this esc or any other swordfish esc's so I'm kinda stumped. I have to be doing something wrong??? Anyone have one of these that can chime in??
  • urbs00007
    • Jun 2011
    • 826
    are your batteries fully charged? throttle end points set?
    • jcald2000
      • May 2008
      • 774
      Did you program the esc per the directions?
      • photohoward1
        • 1611
        Jim means did you program it for you transmitter with the throttle as per instructions. It detects end points tho way.
        • forescott
          • 2686
          I did not calibrate the radio to the esc. Can't seem to find the instructions. Got a pm from another member on how to calibrate. Should do the trick. Will give it a shot today. Thanks guys!!
