Which Delta Force?
  • electric
    • May 2008
    • 1744
    Which Delta Force?
    I am trying to decide which Delta Force to purchase. The 29 or the 33? I am going to use this boat just for fun and informal oval racing. I will be racing a Synchron and a SV27. I also may have to go up against a Triton later on (My brother has the parts, just has not put it together). The batteries I have are LiPo's 4s2p. Not sure if I have said that correctly, but I am running two of them for a total of 14.8 volts. I also have a set of 11.1 volt batteries for a total of 22.2 volts. I have a 120amp High Voltage (50volts) Hydra ESC. I also have a Feigo 9xl and a 10xl.
    With all of that said what would you recommend that leverages the parts I have. I would like the 33 (have heard good things about it), but I am not sure if I have the right mix of hardware for that size boat? I would welcome your opinions.
    Thanks.
  • highndry
    • Nov 2007
    • 664
    Boats don't win races, drivers do.
    • Steven Vaccaro
      • 8721
      Man you covered alot. Racing a syncron and sv, if you want to keep things level, go with a 29. But the items you have fit a 33 better.
      • electric
        • May 2008
        • 1744
        Thanks. Steve I should also note that all the items that I listed off were purchased from you at one point or another. Except the batteries...
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          As you stated more of a sport boat. I would go with the 29. The proposed electronics and motor are very similar to my 29 setup with an X440/X442/X640 and Fullers hardware, 4S1P 25C 4500. The 33 properly kited out is a race boat
          Douggie
