short flex cable filling hull with water
should it be pushed right down to the bush?FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1pComment
If you are using a 9/32 stuffing tube, it won't fit into a 3/16" stinger. You will either need to use a 1/4" tube and run linerless or use a 1/4" tube insert into your 9/32" tube so you can still use a liner. Kintec sells these as brazed stuffing tubes, but they are easy enough to make.Comment
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Sam 6mm thrust bearings are quite difficult to get in the UK, go to rcbearings.co.uk he has them in stock & is a good guy to deal with, they have 6x12x4.5 @ £2.99 or 6x14x5 @ £2.45 + postage which the last bearings I got I think postage was £1 or £1.50.Comment
Thanks Martin
Just about to order a Thrust washer from rcbearings.co.uk 6x14x4.5
but if the shaft on the T600 motor is 6mm will I need to find a bearing at 6.2mm? or is the shaft 5.8mm so it will accepts a 6mm collect?
I am not near the motor right now so I cant measure it. also dose anyone know the size of the bolts the mount the T600, would like to order two that are a little bit shorter than the one I have at the moment but just got lucky with a few I had but thet are a bit to long are they M5 ?Last edited by sampit; 01-16-2014, 05:59 AM.FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Sam on thrust or ballraces the allowances are made on the motor shaft for example on 5mm shafts the ballraces are 5mm id & the shaft is ground 4.97 - 4.98mm. Think about it if all spindles or shafts were full size ie 5mm you would never get the shaft into a ballrace, I know yours is 6mm but used 5mm as an example as that's what I have handy.Comment
Great, I thought that might be the case Martin, makes perfect sense just thought i would double cheeck. i will order one now.
Does the thrust need to tight against the collet and the motor mount,or do i leave a mm or two or does it need to bind all the time,if that makes any sense.FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
If you do leave a gap make sure its less than the end play their is on the motor shaft otherwise the thrust bearing isn't doing anything as the motor ballrace will still be taking the load & not the thrust bearing. I generally just leave a few thou clearance gap, once under load theirs no gap.Comment
OK thanks I have just ordered one, we will see how it goes.
Im not that happy with my stainless 6mm 3 piece collect I have, but they are even harder to find in the UK 2 piece even harder to find!
what i have done is locktighted with 638 the 3rd piece of the collet to make it a two piece a bit of a bodge i know, but have no other options, as I can never remove the 3 piece collects from the shaft.
might try some Anti seize paste,if i can find any at the right price, damm that stuff is expensive, would copper grease do?
one last question T600 1400kv Timing would 11 degress be about right?Last edited by sampit; 01-16-2014, 08:57 AM.FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Re 6mm 2 piece couplings in the UK, Model Marine Supplies stock Octura 6mm x .187" @ £11.95 + post, Speak to Tony another one of the good guys to deal with. Not sure on the length you can get in your boat but these are 35mm long o/a.Comment
Sam.
Martin made a valid point in post#19. I'm not sure if you saw it as you haven't made a comment on it.
Most stingers have a gap between them and the transom. The base of the stinger then acts like a scoop if it is not sealed.
A bit of silicone sealer will fix it. But as Martin said a simple seal can be made.
I use a piece of soft silicone tube that fits over the stuffing tube & into the stinger which compresses as the stinger is bolted on to the transom. .
Here's a couple of pics.
One shows the piece of tube in the stinger, with the piece of nitro muffler extension tube it was cut from, sitting on the trim tab.
The other pic shows it all bolted up.
Silicone sealant is easier if you don't want to remove the strut.
I normally run the brass stuffing tube into the strut but this boat was a RTR thing & that's how it was installed. Only just exiting the transom.
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
