having trouble programming t180aesc
  • pugman2
    • 236
    ok i have finished my cooling mods sprayed circet boards with corrosion x re assembembled and went to program esc have a programmer from hobby king that confuses me . am using stock pursuit motor to try first before i buy a motor. motor running in reverse but trans says forward motor red is to red and black is to black . on my programmer it goes 1 - thru 4 but timming is in another set cant get to anything other than 1-4 dont know what to set timming at seen differnt conflicting numbers in search postings on turnigy 1620 stock motor ? so dont know what to set timming at once i do figure programmer out will post pic of my programmer to clarify
  • pugman2
    • 236
    • pugman2
      • 236
      the non seaking is the one i have which does not have timming and all that on 1-4 must be for a car but thats what they sent me with esc grr
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        Dude I've read your post like 3 times, and I cannot figure out what your asking.....
        Motor runs reverse and timing issues?
        What's the problem.....
        • pugman2
          • 236
          the programmer i have is in the first pic has like 1 thru 12 steps like for brakes and all that crap but only goes thru 4 steps wich i think would be normal but not options i need like cells voltage cutoff and timming am i making sense i guess i am wondering if they sent me the wrong card
          • martin
            • 2887
            The 2 prog boxes you show are the same boxes, the only difference is the instrutions on the label of the box. When you plug in a marine esc you will only get 1-4 sections come up on the screen. The info that comes up on the screen is from the esc itself & not the box, that's why only 4 modes come up with a marine esc.
            • jkr
              FE Addiction
              • 568
              To change motor direction you have to reverse any two of the three wires on the motor.
              • martin
                • 2887
                The left hand numbers are item numbers & the right hand numbers are value numbers. You need to have the correct numbers in each box then click ok button, you need to do this 4 times in total so your setting all 4 item & values.
                • martin
                  • 2887
                  For example running mode = 1 & forward =1 & so on, as said if motor is running backwards just swap any 2 motor wires over.
                  • pugman2
                    • 236
                    so i can change the sticker on the programmer seen some one had a sticker layout. that being soved does anyone have a idea of timming on stock motor
                    • jkr
                      FE Addiction
                      • 568
                      Is the motor purple?
                      • martin
                        • 2887
                        Yep you can change the sticker or just refer to instruction sheet for marine esc when programing.
                        • pugman2
                          • 236
                          nope its black turnigy 1620 pursiut motor
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            Here is the sticker. Set timing low to start with, too high and you will heat things up. On my Leo's 4082 1600kv I have set the timing at 11.25 and runs cool
                            Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
                            "Follow someone's footsteps and you will always be a step behind"
                            • pugman2
                              • 236
                              set it about 7.5 hope that is low enough
