8mm connectors vs. 6.5mm connectors
  • ray schrauwen
    • 9475
    You have me sold, now that is something to chew on! Cool and thank you! Merry Christmas!
    The good 3.5mm connectors Joerg tested were the inside out ones with a solid 3.5mm OD male and split 3.5mm ID female like these
    Nearly all connectors are made from plated brass (the only exception that I know of are the hollow aluminium 4mm Kontronic connectors) and brass despite having a decent copper content is a p!$s poor conductor at just 28% of copper's conductivity, so if your brass bullet connector was the same size as the wire it would be a huge bottleneck, and it needs to be far bigger than the copper wire to flow the same amount of electricity without heating up more than the wire.
    Nortavlag Bulc
    • rickwess
      • Apr 2013
      • 777
      You're a smart guy Ray. When in doubt, decide what to use based the the current handling the manufacture specs.
      I personally use 6.5mm on all my 4s batteries/motors. Not always for current rating, but it does allow me to only need one kind of charger adaptor.
