Cooling an XL
  • Mich. Maniac
    Banned
    • 1384
    Cooling an XL
    I am using 10XL motors and am using the sv27 water jackets. However these jackets are alot shorter than I thought they would be. To the point you could easily put 2 on. So my quest. is which end of the motor should be cooled? By the shaft or by the wires?
  • Doby
    KANADA RULES!
    • 7280
    Use two and hook them up in series,,,I did it on my SV27 and using silicone to seal the ends,,it works great
    Grand River Marine Modellers
    • Mich. Maniac
      Banned
      • 1384
      well I will do that but I am strapping my motors in rather than mounting them at the end so I need some room for my strap. thanks I wasnt sure if it was needed.
      • lferguson
        • 202
        Stapping them in???? I am not so sure that is the way to go.... You might want to rethink that. I am not saying you don't have a great setup nor and I in anyway saying you don't know what you doing. What I am saying is that you have already mounted your stuffing tubings. It is going to be SUPER hard to get a even decent alignment and have them strapped in well enough to were they don't move at all. You have to realize there is tramindious force in the boat when it does anything other than run perfect at high speeds.
        • Mich. Maniac
          Banned
          • 1384
          NOW you tell me!! No one ever said strapping wasnt good. I guess I never asked. yeah Im using rather thick steel bent on a press break and will have rubber inside to the motor. I think it will work well. Mounts are gonna be about 25 mm wide. Or 25 of the 73mm that the motor is long. Those will then be screwed into the hull of boat, well, A mounting plate in hull of boat.
          • Mich. Maniac
            Banned
            • 1384
            stuffing tubes arent permanent yet. Im actually just ordered more from FD cause I wanna bend them with my new tubing bender!
            • brooks93
              • 89
              I would ditch the straps also.
              as far as cooling goes the Lehner alum. water jackets will fit xl size motors and are 100% better then the silicon ones on the SV.
              if I remember right Steve sells a alum water jacket also that should work.
              seasoned newbie
              • ED66677
                • 1300
                Got a good trick for you!
                use a piece of tube a bit larger than the motor can (whatever material you have), glue some brass tube on it, find (or make) too big seal of silicon rectangle section, stick them all together!
                I made one for my 8XL from a fiberglass tube, I tested it only static with "mouth" pressure no leak at all!
                I work for a American Company, in the French sub, this company manufactures Powder Coating systems (and a lot more!) and I've use parts of an old Powder Spray Gun!!!
                I'll post some pix of it soon!
                Emmanuel
                • ED66677
                  • 1300
                  check this out http://perso.orange.fr/pleindetrucs/index.htm
                  Emmanuel
                  • Steven Vaccaro
                    • 8723
                    The rear bearing end is the end I would put the cooler on.
                    • ReddyWatts
                      • 1711
                      cooling plate
                      Interesting design for a controller hollow cooling plate.
                      ReddyWatts fleet photo
                      • ED66677
                        • 1300
                        same kind of design is used for PC's chipset or CPU watercooling
                        Emmanuel
                        • ReddyWatts
                          • 1711
                          same
                          That would work on some of these new HV controllers.
                          • ED66677
                            • 1300
                            that would work on any esc where the original heat sink is not glued!
                            Emmanuel
