new to this
  • Wes Rose
    Banned
    • Dec 2013
    • 68
    new to this
    i have a miss gieco.17 inch and a miss gieco 24 inch..can i make these boats faster without going brushless.mabey by changing the props or bigger brushed motors. yea im a newbie
  • JimClark
    • 5907
    better off going brushless or trying a lipo battery in place of the stock battery. maybe even go up one cell and use a 3s lipo
    Billy Graham
    • lenny
      • Sep 2010
      • 4294
      What kind of cells are you running in the 17" cat now and what do you plan to run in the 24" cat nimh or lipo ?
      How hot is the stock setup temps after a 4 minute run at full speed ?
      Also why do you want to stay brushed and not just go brushless ?
      ? ONLY IF THEY WORK
      • Wes Rose
        Banned
        • Dec 2013
        • 68
        well i dont understand all.the terms of the amps the esc amps and motor
        or what size motor. im really new to this.lol ps .can i use a lipo battery with a brushed motor and also.the boat comes with a 6cell nmh battery.
        • Wes Rose
          Banned
          • Dec 2013
          • 68
          also what is stock set up
          • Fella1340
            • May 2013
            • 1035
            3s lipo will liven it right up! Playing with props staying close to stock or one larger prop, good times. all my bruwhed boats and trucks use lipos. If you go ,3s get a low voltqge alarm. Very cheap. Greqt runtimes to!
            • Wes Rose
              Banned
              • Dec 2013
              • 68
              thanks .one question.what about the low voltage cut off.will i damage a lipo battery with this stock esc and no lvc
              • Fella1340
                • May 2013
                • 1035
                You can purchase a 3s low voltqge alarm. It plugs into charging leads on the lipo battery. The alarm is quite loud and can be heard from a good distance. I always made sure I made a pass close by regularly. It still works great on a brushed cat I have. It was rather slow and going to lipo using the biggest pack I could get in made it fun enough and really long times made me leave it brushed. I wasna't sure how long the boat would would last with the extra strain put on it but 40 plus runs and things are still great. I bought from hobby king, there under $10 and worth there weight in gld!!
                • Fella1340
                  • May 2013
                  • 1035
                  Running without a lvc alarm is possible. You can time your run once you notice it slowing down bring it in. perhaps use.2/3 or that time for.future outings. I know that if I didn't have the lvc in mine I wouldn't have so many runs in. Even the lvc alarm isn't foolproof, running without one with one slip up and the battery is garbage. Not sure what other damage could happen. Good luck
                  • Wes Rose
                    Banned
                    • Dec 2013
                    • 68
                    ok can i run a 12t 5200 kv brushless motor in my miss gieco 24 inch boat.motor lenght is 30 mm motor diameter is 20 mm .is reccomended for 2 3s lipo or 6 to 7 cell nimh. any help will be appreciated.
                    • Wes Rose
                      Banned
                      • Dec 2013
                      • 68
                      ps.will.this motor be fast
                      • lenny
                        • Sep 2010
                        • 4294
                        Way to much kv for a boat setup,
                        You want 3000kv or lower and it also depends on what volt cells you want to use in the setup.
                        ? ONLY IF THEY WORK
                        • lenny
                          • Sep 2010
                          • 4294
                          Some stuff for you to read and learn from and what it may take to go brushless with these boats.
                          http://forums.offshoreelectrics.com/...-17-quot-build
                          http://forums.offshoreelectrics.com/...Miss-Geico-RTR
                          ? ONLY IF THEY WORK
