Neu 1527 1D setup?
  • ReddyWatts
    • 1711
    Neu 1527 1D setup?
    Has anyone used the 1527 1D on 4s in a cat? Which prop did you use and what were your amps and speed?
    ReddyWatts fleet photo
  • Eyekandyboats
    • 1921
    whats the size of your cat
    you can be able to run a 48-52 MM on a lose cat.
    the 27 has about 40% more power then the 1521.. you will need to run 4s2p only. 1p is to risky for sure!
    EYEKANDYGRAPHICS
    www.rclipos.com
    • ReddyWatts
      • 1711
      Hoping to get someones setup results so I can compare it to the estimates from FeCalc and design some conservative setups and go up from there. Need more info for the estimating 4 pole motor setups in FeCalc. Wanting to start out with a setup running around 50 mph.
      • Steven Vaccaro
        • 8721
        What size boat are you thinking?
        • ReddyWatts
          • 1711
          I am starting out in a 34" supercat and testing this motor with some conservative setups.
          FeCalc says X442, 100 amps, 30000 rpm and 50 mph. Is this close?
          I think max effeciency for this motor is 114 amps.
          • Eyekandyboats
            • 1921
            i just asked that question. and i don't get a reply.
            EYEKANDYGRAPHICS
            www.rclipos.com
            • ReddyWatts
              • 1711
              Sorry EyeKandy, thanks for your input. You always have some really good info! Sometimes I am thinking about what to say, when I should be listening.
              • Steven Vaccaro
                • 8721
                Originally posted by ReddyWatts
                I want to put it in a 34" supercat and start testing this motor with some conservative setups.
                I figure your close. A 1527 1d will drive that boat at silly fast speeds! You could also use a 1521 without a problem.
                • ReddyWatts
                  • 1711
                  Cool! If I am going to invest and test out a Neu motor, I want it to be the crazy fast one. lol
                  I know the supercat has limits and hope this motor will be versatile enough to run in different size hulls and equipment.
                  • ReddyWatts
                    • 1711
                    I am going to set this hull up for straight line running, not oval.
                    When I shoot the juice to it, I want it to stand up and salute! lol
                    • Scott T
                      • Oct 2007
                      • 590
                      Mad Mike on RRR is using this motor in a 35" sprint cat on 4S2P - he loves it.
                      See post - http://www.rumrunnerracing.com/fefor...ght=sprint+cat
                      In another thread he wrote "My cat does 64mph with the 450/2 and everything was good heat wise motor and speedo 110-115. The batteries were the warmest at 129 after the full mile race".
                      Cheers,
                      Scott
                      Scott Tapsall
                      Pine Rivers Model Powerboat Club - Facebook Page
                      My Gallery
                      • ReddyWatts
                        • 1711
                        Scott thanks.
                        I liked his comment about running this motor in a mid size cat.
                        The Grunt on the 1527 is crazy, the boat sounds "ANGRY" when it's running, like it's pissed it's only on 4S....LOL This thing runs like a rabid cheetah on crack!!!!
