run time TP4040
  • sampit
    • Jul 2009
    • 447
    run time TP4040
    Just wondering what kind of run time I could expect running a TFL Popeye Hydro on a TP 4074 2200KV y motor using a single 4s 5800 or 4s 5000 and also would I be better using a 45c pack or would a 25c work ok. and would i be ok on a M545 prop
    thanks
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    What prop? What speed? You could easily pull 100-130 amps - or more -depending on the prop and how wet the hull runs. A 5000 mAh 4S pack will run for 2.5 minutes at 100 amp average discharge rate before it reaches 20% capacity, a safe stopping point. You will not want a 25C pack.
    • sampit
      • Jul 2009
      • 447
      Not Sure Jay never had a Hydro before exept a small vortex 22" thinking maybe a M545? just after advise really, just read that a 6s setup in this hull would be too much so going to run 4s
      I have a new TP4074 2200kv motor I could use, not for racing, but just sport running to get a much run time as I can, speed around 50/55mph would make me happy
      • sampit
        • Jul 2009
        • 447
        Another setup option i was thinking about may give me a bit more run time. or maybe less, but it looks a nice setup
        trying to avoid a 4s 2p setup if possible.
        http://forums.offshoreelectrics.com/...ommend-a-setup
        post 9
