hammer ep upgrade -need help!
  • cheesemonkey23
    • Jul 2008
    • 2
    Hi- I need help on upgrading my aquacraft hammer ep. Does anybody know what engines, propellers, or speed controls are needed to make it go faster? I can't find the right size motor or propeller anywhere. If someone could help me I would greatly appreciate it!:help
  • ReddyWatts
    • 1711
    Can someone help this new member?
    ReddyWatts fleet photo
    • cheesemonkey23
      • Jul 2008
      • 2
      anything will help
      • Ocean Racer
        • Sep 2007
        • 502
        From my understanding a Hammer motor is a 550 size can. If you want to hop it up try a 19 turn motor in it. Im not sure what the stock esc is rated maybe somone else knows. But just to be safe get a esc that can handle a 19 turn. Usually esc's have a range of turns they can handle. The stock hammer motor has a lot of torque and works pretty good in a X-cellerator.
        Failure is the First step to SUCCESS
        • jrod2292
          • Oct 2007
          • 24
          i have one and i was going to upgrade it so i did all the research but then i got a villain and haven't looked back. But as i recall, the esc to get is this http://www.offshoreelectrics.com/pro...rod=dh-prb2314, and a 19 turn speed 600 motor, i was looking at the great planes one from towerhobbies, http://www3.towerhobbies.com/cgi-bin...?&I=LXJ766&P=7. i don't recall props but there is a huge thread on this over at rcuniverse. here it is http://www.rcuniverse.com/forum/m_20..._1/key_/tm.htm, on the first page, scroll down a bit and theres a post by 48chebbie on the perfect "recipe". theres also tons of info in that thread and it'd also be easy to upgrade to brushless if you want
          Jarrod
          • jrod2292
            • Oct 2007
            • 24
            the thing about the hammer is that its such a simple design so theres a mllion different setups that it'd run good on. the problem is that its got a subsurface drive, but as long as thats taken into consideration, you shouldn't have a problem.
            Jarrod
            • Ocean Racer
              • Sep 2007
              • 502
              The only problem that i know of is the stock hull likes to cavitate. And that is not good this means that
              from a certain rpm and up that high rpm motor is useless. From what ive heard i think they said 25mph
              is the limit with the stock setup. Also the the through hull design limits the size of the prop that can be used.
              • jrod2292
                • Oct 2007
                • 24
                yea, i have one and it cavitates a ton, not very much fun if you ask me. But if you want to seriously upgrade then you can turn it into a surface drive pretty easy, but it isn't really needed. For some 25mph could be plenty(yea, right) and i have read that the proboat esc and a speed 600 19t are the best upgrade. from there the next step would be changing the driveshaft so it could fit other props, Steve has an article on this
                http://www.offshoreelectrics.com/inf...-aquacraft.php
                but once again you run into the problem of it being a subsurface drive. But as long as you go into this knowing that as a limitation, it should be a lot of fun
                Jarrod
